Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Flow new machine (Saeco primea touch plus cuppaccino) went well for about 100 cups. Now the flow of coffee from the front nozzle is reduced to a drip. We have cleaned the brew head, coffee clean etc
    Sergeant:
  • Saeco Expert
  • 223 Answers
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
www.CeriniCoffee.com
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Posted on Nov 25, 2008
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
I have a Saeco Primea Cappuccino Touch Plus. how do I adjust the machine to make the coffee fill up a cup or mug(using different size). Can the machine work out the size of cup used automatically.
Yes, you can adjust the sizes and aroma according to your taste,just hold the the product without releasing your finger,the screen will show programming.Then follow the instructions on the screen. Easy.
Apr 26, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Touch Plus flow problem
In the bean hopoer there is a little screw. Remove this screw and the cover and you will see an adjustment alan key. You need to push down and rotate the adjuster counter clockwise to make it finer and clockwise to make it bigger. Make sure you only rotate the grinder a little at a time, 1/4 turns at a time recommended. Make 2 cups then readjust if necessary.
Saeco Authorized Sales & Service of Espresso Machines
Nov 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
257 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
