Hi when i tried to install anew ram an error occured. the error message was OC fails . My motherbored is gigabyte
    Scholar:
  • 135 Answers
I think your motherboard bus speed not support the ram which your are going to install.
for more specification check your motherboard manual how much bus speed it support and then check your ram bus speed.
If you provide your motherboard name then this will be more better for to detect problem.
Hope this will solve your problem.
Posted on Nov 23, 2008
Error 15 in DFX 9000 printer
Error Code 15: OC Driver Error
This error occurs when the Mechanism Control ASIC detects that a
single phase of the OC Motor was energized for longer than the allowed period of time. This indicates a malfunction of either the HCPP motor, or ROM Board driver circuitry (TA10: STA485A), or both.
1. Check OC motor connector CNO/C on the Sensor Board.
2. Check both the OC motor and the OC motor driver circuitry on the
ROM Board. To replace the ROM BOARD If necessary, replace the OC MOTOR
Jul 27, 2014 | Epson DFX-9000 Matrix Printer
Gigabyte geforce gtx 650 oc 1gig
GEFORCE GTX OC.
THE OC STANDS FOR OVERCLOCKED.
Jun 23, 2013 | Computers & Internet
OC failure after changing power supply
oc failure computer.
oc failure boot.
oc failure error.
oc failure bios.
oc pc failure.
oc power failure.
your description don't have so many details.
GOOGLE IT.
Jun 11, 2013 | Gigabyte Computers & Internet
Installed MS Office 2007 on XP Home Edition version 2002. Message install was successful, however, try to run application and get error "application has failed to start because the app configuration is...
Update your OS to XP service Pack 3 from microsoft.
If your operating system do not have any service Pack(SP) ie minimum SP2 yet, your M/S office 2007 will not function.
Do your Operating system meets the below requirement?
Microsoft Office Basic 2007 requirement:-
CPU: 500 megahertz (MHz) processor or higher
RAM: 256 megabyte (MB) RAM or higher1
HDD: 1.5 gigabyte (GB); a portion of this disk space will be freed after installation if the original download package is removed from the hard drive.
Drive: CD-ROM or DVD drive
Display: *1024x768 or higher resolution monitor
OS: Microsoft Windows XP with *Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system
*Internet Explorer 6.0 or later, 32 bit browser only. Internet functionality requires Internet access (fees may apply).
Aug 30, 2010 | Microsoft Computers & Internet
Problem loading XP Serve Pack 2 in Gigabyte 8I845GVM-RZ
I know this may sound mundane, but did you load the correct set of windows drivers for the Intel 845 chipset? I mistakenly loaded the Home drivers onto a unit I tried to install Pro on and I got all sorts of errors.
Mar 26, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Network & Speed Problem
I suspect that the network interface card failed, & that's why you get the error message. Try disabling it from the BIOS & see if the error message disappears. If it did, then you have a failing network interface card & need to install anew one.
Jul 22, 2008 | IBM Netfinity 3500 M20 8657 Server
Cannot load windows
hi cpfish,plz do let me know what kind of error message do you get when you are doing the setup so i can get you the best solution.
raj..
May 12, 2008 | Gigabyte GA-8KNXP Motherboard
Bsod when i tried to install win2k
Error Message: PAGE_FAULT_IN_NONPAGED_AREA
Explanation:
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Nov 20, 2007 | Microsoft Windows 2000 for PC
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
