Question about Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Wont connect to my computer:@
I got my Samsung yp-z5 for christmas and i put the usb and disc in the pc and the mp3 wouldnt connect to my computer so i tryed it in my brothers without the cd and it worked and now i need to know how to connect it to my computer all it does is pop up new hardware found and that says MTP device and i click on onit and nothing happens //HELP\\
    Problem Solver:
  • 10 Answers
Have you downloaded, windows media player 10 or 11, because if you have a different version of windows media it won't work. I had the same problem, but it was fixed in seconds!!
Posted on Feb 11, 2007
SOURCE:
I need a replacement usb cable to connect my samsung YP-Z5 MP3 player to my computer
You can purchase a replacement USB cable for Samsung YP-Z5 MP3 Player from amazon >>LINK
Oct 23, 2011 | Samsung YP-Z5 MP3 Player
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5
Vista = not compatible with this player
Apr 18, 2008 | Samsung YP-K3 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
How do you down load music from CD on to your YP-Z5 MP3 ?
you should have a usb cable to connect the player to the pc.
if you have a music folder, open it, choose files you want to load, open edit at the top of the page, hit copy, then open the disk in my computer that is the player, and hit paste under edit at the top tool bar
Feb 01, 2008 | Samsung YP-Z5 MP3 Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
My samsung will not connect to my computer
please help!!!!!
i have a samsung GT-S5600V ive installed the software for it 'USB cable' and 'Samsung new PC studio' and ive connected my phone to the computer through the USB cable and its not searching for the device it keeps saying 'the device cannot be opened because another program is currently using it.close the program to connect the device.move to search new device' and im gettin really annoyed PLEASE HELP!
Nov 14, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
I can't connect my samsung yp-z5 to the computer!!!
Try installing the Samsung Media package supplied with the player. Then restart your PC - all programs should then recognise the YP-Z5
Jan 16, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Open Questions:
Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Logo
43 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
