Question about Vacuums
Washing machine outer door
Dyson contrarotator CR01, display reads close outer door then press start, even when it is shut ? Is there a way of overriding this fault.
  • jedilance Dec 02, 2008
    The outer door of my machine DC01 is closed but the display reads it is not.
The solution was on your website, someone had already had same fault and posted the solution.
Thanks
Tracey
Posted on Nov 23, 2008
My Dyson Animal V6 only operates in short bursts of about a second. I have charged it fully, but I still have this problem. What is the cause and what can be done about it?
if its under warranty, I would take it back, typical fault with them is the motor failing, it over heats or the sensor senses a fault and shuts down.
Apr 09, 2017 | Dyson Vacuums
Dyson dc07 clear dust bin will not close after emptying. Any time the bin is removed, the dirt falls out.
There is a lever that has a hook on the end that holds the door in the bottom of the dirt cup closed. If the little plastic hook gets broken the trap door will not stay closed by itself. The easiest way to fix this is to purchase a new dust bin. I have a bunch of them in my vacuum graveyard. You may call my store at 260 244-4696.
Apr 05, 2016 | Dyson Vacuums
The exterior canister, wheels and casing are covered in dust after every use. After 2 months all filters look brand new.
Hi there, it's Jack at Dyson.
It's normal for your Dyson vacuum to generate harmless static in use, especially when the machine is new. This is due to fast-moving dust and debris passing through the vacuum's ducts. It can also be affected by humidity, and by the synthetic content of the carpeting you're using the vacuum on. The static charge can cause airborne dust particles to cling to the vacuum's outer casing. Our machines include airtight seals, which mean it's extremely unlikely these particles would have come from inside the machine.
Briefly wiping the machine with a damp or anti-static cloth after use should help to dissipate any static charge.
DC65 uses Dyson cyclone technology to capture even microscopic dust and allergens inside the clear bin, keeping dust away from the two washable filters. The fact that the filters are still clean after several months' use simply shows the cyclone technology is doing its job effectively, and does not suggest a fault with your machine.
To reassure you, we'd appreciate the chance to take some further details, and to discuss your concerns. Please give the Dyson Customer Helpline a call on 1-866-693-9766 (US) or 1800 239 766 (AU) to talk with our experts directly.
We'll look forward to speaking with you.
Mar 14, 2015 | Dyson DC65 Animal Bagless Upright Vacuum
My dyson shuts off after just a few seconds of run time.
Make sure the charger is operating. Then if it is, look at a failed battery.
Jan 13, 2015 | Dyson DC16 Root 6 Bagless Handheld...
The closing mechanism on my dyson dc59 comes open when I touch it. It only has one red closure tab is it suppose to have two
DC59's bin base is engineered to open when you press down on the red release catch, as shown in our Getting started guide:
The bin base should shut securely after you've emptied the bin. If you're concerned it's not staying closed, we'd appreciate the opportunity to help you check everything is correct with your machine. If a replacement part is needed, we can also confirm if this is covered under our 2-year cordless guarantee.
When you have your machine easily to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can help.
Oct 05, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
Root 6 sill not shut off
Hi there Mike, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC16 handheld. If you've found a replacement battery has not resolved the issue with your machine, there may be a fault with the main body assembly.
We'd be happy to take you through some quick diagnostic checks to help confirm what may be causing the fault. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 05, 2014 | Dyson DC16 Root 6 Bagless Handheld...
My (newly acquired/refurbished) Dyson dc35 motorized head will not stop rotating even when button is not pressed. Starts rotating as soon as it is clipped on vacuum and drains the battery. This cannot be...
Hi, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC35. If the brush continually rotates when attached to the machine, this sounds like there may be a fault with the main body assembly.
I'm not sure if you've purchased your machine directly from us, but I would encourage you to contact us so we can confirm what may be needed to resolve this situation. You can reach the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Oct 25, 2013 | Dyson DC35 Handheld Vacuum
Dyson washing machine error water level too high
I'm sorry to hear you're having difficulties with your Contrarotator. I'd encourage you to get in touch with us directly so we can provide further assistance. You can call us free on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Service
http://www.dyson.com/
Jan 15, 2012 | Vacuums
Sharp microwave carousel R330J 1100 watt. When the heating cycle is started the microwave light flickers on and off and there is a clicking sound. Initially high voltage fuse blown. replaced fuse and...
Hi and welcome to FixYa. I am Kelly.
1st the model number appears to be incomplete. Not an issue at this point but will be if you need parts.
You most likely have an interlock problem with one of the 2 door switches or the door interlock mechanism is broken.
There are 3 safety interlock micro switches activated by the door. One for the light, one for the Magnetron and one for the control panel power. If the problem persists with the Magnetron disconnected. The Magnetron safety interlock micro switch is supposed to blow the fuse if the unit is energized with the door open. Check continuity of your door interlocks. Pat particular attention to the NC (normally closed), C (Common) and NO (Normally Open) contacts.
NC should read to C and when the switch is activated read open at which time the NO contact will read to C.
I really suspect a bad microswitch.
Thanks for choosing FixYa.
Kelly
Aug 21, 2010 | Vacuums
Vacuums Logo
587 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
