Question about IBM ThinkPad R52: R52 P M 760(2.0GHz), 512MB RAM, 80GB 4200rpm HDD, 15in 1400x1050 LCD, 64MB ATI Rad... (THINKPADR52R52PM76) PC Notebook
Lap top Presario 2000
I have fogotten the power on password of my laptop.
Now it is not starting even powe on led is not comming. Please help !
Reset bios password
unplug the cmos battery from your lap and start the system but before that u have to also eject the laptop battery and power cable and start your lap without lap battery and cmos battery
Jun 28, 2013 | HP Compaq Presario CQ60615DX Notebook
How do I reset the power on password on my Compaq presario C300?
1.Reinstall the whole thing...
2. Enter the Bios and attempt to reset. (Unlikely)
Jan 13, 2010 | Compaq Presario Notebook
Don't Turn on. LED just turn on/off but don't start.
They will not replace it, they will repair it.
It is possible the problem is caused by a faulty battery or even a faulty power cord.
I cannot say where you shoulod take it for repair because i have no idea where you are located. So I therefore suggest you take it to any Outlet that sells/repairs Compaq listed in your phone book.
Kindly rate our help++++Thanks for using FIXYA
Oct 16, 2009 | Compaq Presario CQ50-215NR Notebook
Got power, frozen machine
okay what you need to do is if you have the system restore cd use that , it will reformat your lap top even if it cant reboot just put in the cd when you start up the computer and it will restore everything you may lose alot of things but atleast your lap top will work after , if not then Reply to me at Jonk3y at Aol.com and i will gladly help you with your problem
Sep 23, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
I forgot my password on COMPAQ Armada lap top. How do I cancel or find it. It wont start or turn power on!!????
You have to get to the Set-up. Press F-10 when it start.If is not starting plug it in receptical,your battery is not charged.
Mar 31, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario C500
if you don't have driver disc,then you can find it in driver databases
Feb 03, 2009 | Compaq Presario 700 470024-192 Notebook
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
Basically my on buttong got stuck and when I was trying to get it out the front cover thing came of. Together the wires also came out.On the end of the wires it has...(POW S/W),(POW LED),(HDD LED). Please...
Ha Ha Ha, well your front cover thing is where your power on button and LED lights reside. the POW is your power wire that connects to your power switch you pried out of your front cover thing, or your power switch. Your POW LED is the wire that connects to the light that lets you know your computer is on and running on your front cover thing. and of course the other wire connects to the other LED light on your front cover thing. Good Luck. also, you can change the wires around until you get it right.
Oct 28, 2008 | E-Machines Computers & Internet
Need system unlock code for dell latitude
So I bought a Latitude D620 and I bet u heard this a million times already it came with the famous This system #xxxxxxx-xxxx, is protected by a password authentication system. Any help from the gods of this site would be appreciated. below are the numbers needed i believe,
CHZ0P2J Service tag
272-081-320-75 Express code
This system #CHZ0P2J-595B is protected by a password authentication system.
Any help would really be appreciated. thanks in advanced.
Nov 04, 2007 | Dell Latitude C400 Notebook
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
