Back to:
Tags:
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Door Problem
posted by Baldrick on Jan 10, 2007
When we open the dishwasher the door drops down and bounces.
Is it possible to limit the speed of the fall of the door?
Many thanks
Chris
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 11, 2007
Helpful (85)
gwol
Rank:Guru Guru
Rating: 92%, 171 votes
There are set springs for the adjustment of the doors on the Bosch dishwashers. they are colour coded for different applications. They are accessed by laying the machine on its back and pulling the springs out of the base. first you will need to check that the nylon lines which attach the springs to the lower part of the door mechanisms are in place and this can also be done while the machine is on its back. or by first removing the side panels to access the door hinge mechanisms.
If you have a custom cabinet panel on your machine it may be too heavy for the springs and new springs will have to be installed.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Door Problem:
I don't want to Accept this solution
Can you Help with these Dishwashers problems?
Bosch 24 in. SGS43C12 Classixx...
My dishwasher starts ok but seems to get stuck during the...
hi, i have read a few posts on here but cant find the...
My dishwasher has always worked great. I recently changed...
the detergent dispenser will not stay shut for more than a...
Hi, I have a Bosch KGV2620GB/03 fridge freezer (bottom...
Loading problems.
Repair Service
Find Dishwasher Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
