Question about Microsoft Computers & Internet
Countblank won't work in the column
Function countblank won't work in the column, if the data is in the data format. I tried 3 to 4 times. Is there any way to get the result if it is the date format in the column.
gopalakrishnarao1@indiatimes.com
  • 45 Answers
Check the format of the cell with countblank formula - it shouldn't be in date format.
Posted on Nov 25, 2008
My I Mac won,t reconize my PNY 4 gb usb Flash drive when I insert it
Try reformatting it:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Aug 17, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
MS excel issue
Using a time format for the data cells and data that looks like 12:00:10 AM the result you want is displayed no matter which formula is used. If the date portion of the data cell is not deleted then the result is 00:00:00. Delete the date portion of your data cells to get the result you want. (For example: When I enter 10 into a cell that is formated for time xx:xx:xx it shows 1/11/1904 12:00:00 AM in the formula bar and 00:00:00 in the cell. When I delete 1/11/1904 in the formula bar and show only the 12:00:10 the cell shows 00:00:10. Then it makes no difference which formula you use.)
Sep 19, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Transforming birthdates into year codes
Here is a solution that might work for you. Please be mindful that there are several different solutions that will achieve the same thing in Excel (I am assuming Excel is your software).
1) Make sure each column in your spreadsheet has a heading.
2) Highlight (select) the column of birthdays.
3) Choose Format from the menu bar.
4) Choose Cells... from the drop-down menu.
5) For the "category", choose Custom.
6) In the "type" box, type yyyy
7) Click OK and when you return to your spreadsheet, you will see only the years displayed. However, when you try to edit a cell, you will see that the entire birth date is stored and preserved.
8) Now, highlight the entire table
9) Then, choose Data from the menu bar
10) Choose Subtotals... from the drop-down menu
11) In the "At each change in" box, choose the name of the column with the birth dates
12) In the "Use function" box, choose Count
13) Leave all other choices at their defaults
14) Click OK, and you are done.
Using this method, you can continue to enter the data as you always have. In that way, the birth date info is never actually destroyed or converted. What you are doing is simply deciding what is displayed.
I hope this helps.
Aug 02, 2009 | Microsoft Office Excel 2007
Entering data for Matrices A and B
Happy for you that you found the solution yourself.
Apr 28, 2009 | Sharp EL-506WBBK Calculator
Count with 2 or more criteria
Can you do this using a pivot table where columns B & C are Row Fields and Count of B&C is data fields.
Jan 17, 2009 | Microsoft Excel for PC
Excel function
an2net21,
The simplest solution is to use the if function.
In your example you coudl use:
=IF(A1="girl",1,0)
IF "girl" is in a1 then b2 would show as 1.
If anything else but "girl" is in a1 then b2 would show as 0.
Feb 25, 2008 | Microsoft Office Professional 2007 Full...
Formula for percentages
column d = column c divided by column b. result can be formatted to 3 decimal places or anything you prefer.
Sep 09, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
