Question about HP Deskjet D2360 InkJet Printer
Light is on but printer does not print
I have checked all info available through my help which checked drivers etc but the printer does not respond
My printer does not work
Posted on Jan 13, 2009
Systemworking printerworking butnotprint
Posted on Dec 22, 2008
What could be the problem?? I have recently started to get somewhere with my designjet 430 printer, teething problems getting the correct drivers proved a problem but have that sorted! I have now ran...
Hello.
If your running windows 7 then it will have issues printing correctly. as of yet HP have not provided a driver to support this model. More info is available from HP regarding this.
With the first issue how long do you leave it before removing the cartridges? the lights on some models do this during there "warm up" process. this can take from 30 seconds up to 5 mins depending on what the printer thinks it needs.
Regards GM
May 27, 2011 | HP Office Equipment & Supplies
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
When I try to print the triangle with an exclamation point flashes and doesn't print
This is the 'Attention' light. It indicates that the cartridge door is open, or that other errors exist.
Not great info, but you need to methodically eliminate the possible causes of the error....
1. Try putting some paper into the Manual feed tray / slot. It may be waiting for you to feed paper manually. Check your printer driver settings....
2. Press the 'Go' button. It will make it print from Tray2
3. Check your Printer driver settings, and 'Page set up' in the application
4. Switch the device off, and unplug the data cable.
5.Switch it back on.
6. Print a configuration page from the printer control panel by pressing the Go button (the green one) until the green Ready and Error light start blinking.
7. If it prints these pages successfully, then the problem may be elsewhere (PC software, application, corrupt data, etc) but check the settings on the Configuration page as well.
Make sure they match your system, paper size and type, feeding options etc....
Dec 21, 2009 | HP LaserJet P2015dn Printer
Canon pixma iP8500 won't print, blank pages
The colour cartridge is badly clog. put tissue with warm/hot water below the head, wait for about 30 minutes. If tissue is coloured, the dried ink inside head is out. Is it not, do suction from the outlet pipe of head cleaning mechanics.
May 27, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Printer does not respond, and we restarted it and it still does the same thing When I click the print command on my computer, the printer does not respond.
Try reinstalling driver, change the data cable between the printer and the computer...
Hold down the paper feed button while turning it on (or the change ink button) and it should print a self test...
for info on self test instructions let me know the printer make and model...
Matt
Jan 21, 2009 | Office Equipment & Supplies
My canon s200sp is not responding, what should i do?
  • Right click on your printer and you will see there an option that says Use printer.. the option you will click on is "ONLINE".
  • After doing that, make sure that the printer is online already.
  • Try printing.
Hope this helps!
Nov 09, 2008 | Canon Office Equipment & Supplies
My canon mp210 is not responding to printing requests. we have replaced both colour cartridges. note: printer will photocopy a page, but again, it will not respond to request to print a word document, for...
Is there any blinking of light when the print command given. Any error message at printer display or Computer Screen ?
There is some problem in printing options. Please check and make default setting in the Printer properties. Go to Control Panel --> Select the printer --> Open printer window --> properties --> make them defauls --
During print command check whether the spooling in printer window goes completely or not (if it stop in middle )
Let me know in brief to solve this problem before going to reinstall printer drivers and do not vote till you recieve a good solution for this problem.
Nov 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Not printing all info
try a test page first, please, and let us know the results.
May 10, 2008 | Canon PIXMA iP90 InkJet Printer
HP Deskjet D2360 InkJet Printer Logo
Ben Johnson
