Antenna broken off inside the base piece on the fender. Have from dealer a new antenna and cable assembly. Do I access the assembly by removing the plastic liner under the fender. Also, do I also need the base that sets on top the fender? It is a separate part. I tried to remove the broken antenna piece with an easy out but only made matters worse.
SOURCE: Rear brakes chrysler voyager 05/01
There should only be two bolts on the back of the caliper holding it into the knuckle. Removing those two bolts should free the caliper. In fact I believe they're 12 or 13 millimeter bolts.
SOURCE: Removing the windshield washer reservoir in a 2002 Chrysler T&C
REMOVAL
INSTALLATION
SOURCE: how to remove injectors
Take the bolts out of the fuel rail and lift the fuel rail off the injectors then remove injectors
SOURCE: chrysler 2004 sebring manual
remove the hidden screws be hind mini covers, start from the bottom of panel with panel tool and pry the plastic retainers away from the door plate and remove the wire connectors form switches and replace the handle, reverse the order, GOOD LUCK, RDJRP
SOURCE: Stuck hood latch on 1996 chrysler concorde- Possible broken cable
take off the left front wheel and fender well. slice off the hood cable insulation get a hook too pull the wire have a buddy pull up on the hood while doing this. Should pop open then hope this helps u out.
