Question about HP DeskJet 845c Printer
Ink level problem
I hv hp deskjet 845c printer.But recently my printer has stopped printing(both black & white and color).I think that ink in the cartridge is finished.Now can anyone plz help me how to check the
ink level as I'm unable to find it.
Thnx in advance
  • phantom the cat
    phantom the cat Nov 23, 2008
    what mosesclive has told I hv done already.Now I just need to check ink level in hp deskjet 845c printer.Plz help me
  • Anonymous Dec 25, 2008
    i just changed the black ink cartridge in a 845c and it still is not printing black. anyone have a solution?
    Scholar:
  • 191 Answers
Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test.
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges. If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File.
  2. Click Print.
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK.
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start, click Settings, and then click Printers.
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties.
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup. Under Printout, select one of the color options. (If other optionshave check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color. Under Color Control, choose a color option, and click OK. If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale. If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK. If you are using Windows 2000, in the Advanced tab, click Printing Defaults. Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK.
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Posted on Nov 23, 2008
I have a HP Deskjet D4260 and when i print something using HP Deskjet D4200 series its black and white. I need the pictures to be in color
U must be using HP74, 75 cartridge for your printer.
There are few reasons you are getting black and white (gray)...for printing job.
1. No color ink.
- If you are out of color ink.. that's what it happens.
- check your ink level through control panel.
2. Printer set up. (I think this is pretty much the reason you are not getting color)
- First, check your printer setting.
If they are on gray scale mode, pls chang to color.
How? when you click the print (through file manu), there are option for control panel on your screen. Click that option and will see some detail option you can choose from size, print quality.
Among the print quality option, pls choose, color mode instead of gray mode. That's it.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Deskjet D4260 Printer
HP Deskjet F4280 will not print ink. Both black and color cartridges are full. Upon pressing print the printer takes paper and feeds it through, but the end product is a completely white, untouched piece...
Did you recently changed the ink and if yes did you put them in there respective places if yes check in the printer properties the level of the ink shows full if yes just do the mantainance like cleaning head nozzel and calibrate the head.thats its hould be fine
thanks
Dec 10, 2010 | Computers & Internet
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Hp Deskjet 845c printer's cartridge light blinks constantly.
It probably has, the printer might not detect your cartridges properly, try using new ones
Jun 22, 2009 | HP DeskJet 845c Printer
HP Deskjet Color 845C Printer - Black Cartridge Problem
hi,
try to clean the nozzle with clean cotton w/ alcohol i think your cartridge has getting clog..or maybe it's getting empty!
rey
Nov 02, 2008 | HP DeskJet 845c Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Wont print
Hi, yes I have had problems with these HP printers B4 and it was in fact the INK... strange as it may seem, Ya gota have them "Full" as it were. I have "Fooled" it sometimes by removing the cartridge(s) and powering on & of re-inserting them. But eventually always ended up paying thru the nose for the cartridges. I saved a bit by using refilled ones, but I now use printers that have cheap single color ones, eg: Canon i550
Jul 14, 2007 | HP DeskJet 920c InkJet Printer
HP DeskJet 845c Printer Logo
381 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
