Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Error code meaning
Please my power supply blown, and after it was repaired,it gave an error :call service2
    Problem Solver:
  • 16 Answers
This errror not related to psu section.After repairing this error occurs means its ncu or m.b. not properly packed, where machine last repaird send to that service centre check with this problem.
Posted on May 08, 2008
SOURCE:
My kenmore elite gas range gave a f023 error message?
https://www.shopyourway.com/questions/1040579
Quoting from link shown:
What does F23 error code message mean on Kenmore Elite built-in double ovens? Report This
by Manage My Life
August 17th, 2009 What does F23 error code message mean on Kenmore Elite built-in double ovens? The model number is 790.48143800.
: What does F23 error code message mean on Kenmore Elite built-in double ovens?
Resolution
: Error code
F 23
indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
The error code
F23
can often be resolved by removing power to the appliance for a minute and then restoring the power.
By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
Check to see if the error code is still displayed on the range.
Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed.
Note
: General resolution for problem is based on information submitted with question. If problem persist, contact a service technician to
Sears Repair Department 1-800-469-4663
Sep 07, 2018 | Kenmore Kitchen Ranges
Mitsubishi tv ws55613
The steady blinking light means there is no specific code.
Apr 23, 2008 | Televison & Video
My sharp mx 350 shows error code L8 :1 how will i reset it?
L8-01 error should reset itself automatically after repair. This code means something wrong with power supply or power distribution. It is job for experienced engineer, all you can do is reconnect connectors of power supply harness.
Aug 15, 2016 | Sharp MX-M350 All-In-One Printer
MY MUSIC SYSTEM PANASONIC AK88 THIS SYSTEM ERROR IS F61 PLEASE DIOGRAM OF REPAIR IN MY SYSTEM
As far as the fan is concerned, please reject it as ak-88 is not equipped with 1. the f61 is the errror code for blown power supply ic, you have to get it changed.I have the same system and 2 times i had the same problem. IC is stk 470 0405_28_2012_9_55_21_am.jpg
Feb 27, 2012 | Audio Players & Recorders
My samsung clp 600clpn just says loading on the screen and will not do anything else please help
the power on self test is not completed, means that the power supply is not working properly, you need to replace or repair the power supply board. i have got this problem and it is not the ROM memory, because if the ROM is damadged we can get an error code.
Feb 02, 2011 | Samsung CLP-600N Laser Printer
Hi all, TECRA M10 Model No. PTMB3A000N004 Laptop was on standby and was left open all night. Next morning, no response and would not 'wake'. Laptop was plugged in on charge. Hard rebooted...
take a look:
Power Status Check
The following LEDs indicate the power supply status:
q Battery LED
q DC IN LED
The power supply controller displays the power supply status through the Battery and the DC IN LEDs as listed in the tables below.
Table 2-1 Battery LED
Battery LED Power supply status
Lights orange Quick charge.
Lights green Battery is fully charged and AC adapter is connected
Blinks orange (even intervals) The battery level becomes low while operating the computer on battery power.*1
Flashes orange The power switch is pressed on when the battery level is low.*2
Doesn't light Any condition other than those above.*1 Low Battery Hibernation will be executed soon.
*2 Low Battery Hibernation has already been executed.
Table 2-2 DC IN LED
DC IN LED Power supply status
Lights green DC power is being supplied from the AC adapter.
Blinks orange Power supply malfunction*3
*3
When the power supply controller detects a malfunction, the DC IN LED blinks and an error code is displayed.
Error Code Check
If the power supply microprocessor detects a malfunction, the DC IN LED blinks orange. The blink pattern indicates an error as shown below.
q
Start
Off for 2 seconds
q
Error code (8 bit)
"1"
On for one second
"0"
On for a half second
Interval between data bits
Off for a half second
The error code begins with the least significant digit.
Example: Error code 12h (Error codes are given in hexadecimal format.)
Convert the DC IN LED blink pattern into the hexadecimal error code and compare it to the tables below.
q DC IN
Error code
Meaning
10h
AC Adaptor output voltage is more than 16.5 V.
12h
Current from the DC power supply is more than the limit (6.05 A).
13h
Current from the DC power supply is more than the limit (0.5 A) when there is no load.
14h
Current sensing IC is not normal.
q Main Battery
Error code
Meaning
21h
Main battery charge current is more than 6.05 A.
22h
Main battery discharge current is more than 0.5 A when there is no load.
23h
Main battery charge current is more than 3.1A when DC IN direct charge is off.
24h
25h
Main battery charge current is more than 0.3A when the battery isn't being charged.
q S3V output
Error code
Meaning
40h
S3V voltage is not more than 3.14V when the computer is powered on or off.
45h
S3V voltage is not more than 3.14V when the computer is supports CV and is booting up.
q C5V output
Error code
Meaning
50h
C5V voltage is more than 6.00 V when the computer is powered on or off.
51h
C5V voltage is not more than 4.50 V when the computer is powered on.
52h
C5V voltage is not more than 4.50 V when the computer is booting up.
53h
C5V voltage is not normal when the computer is suspended.
54h
C5V voltage is not normal when the computer supports CV and is suspended.
55h
C5V voltage is not more than 4.50V when the computer supports CV and is booting up.
q C3V output
Error code
Meaning
60h
C3V voltage is more than 3.96 V.
61h
C3V voltage is not more than 2.81 V when the computer is powered on.
62h
C3V voltage is not more than 2.81 V when the computer is booting up.
63h
C3V voltage is not normal when the computer is suspended.
64h
C3V voltage is not normal when the computer supports CV and is shut down.
65h
C3V voltage is not more than 2.81V when the computer supports CV and is booting up.
q PPV output (PCU core voltage)
Error code
Meaning
70h
PPV voltage is more than 1.56V when the computer is powered on or off.
71h
PPV voltage is not more than 0.68V when the computer is powered on.
72h
PPV voltage is not more than 0.68V when the computer is booting up.
73h
PPV voltage is not less than 0.68V when the computer is powered off.
q BGVSNS output
Error code
Meaning
80h
BGVSNS voltage is not more than 1.62V when the computer is on or off.
81h
BGVSNS voltage is not more than 1.02V when the computer is powered on.
82h
BGVSNS voltage is not more than 1.02V when the computer is booting up.
83h
BGVSNS voltage is not less than 1.02V when the computer is powered off.
84h
BGVSNS voltage is not more than 1.62V when the computer is suspended.
q 1R5-E1V output
Error code
Meaning
90h
1R5-E1V voltage is more than 1.80V when the computer is powered on or off.
91h
1R5-E1V voltage is not more than 1.275V when the computer is powered on.
92h
1R5-E1V voltage is not more than 1.275V when the computer is booting up.
93h
1R5-E1V voltage is not less than 1.275V when the computer is powered off.
94h
1R5-E1V voltage is not more than 1.275V when the computer is suspended.
q 1R8-E1V output
Error code
Meaning
A0h
1R8-E1V voltage is more than 2.16V when the computer is powered on or off.
A1h
1R8-E1V voltage is not more than 1.53V when the computer is powered on.
A2h
1R8-E1V voltage is not more than 1.53V when the computer is booting up.
A3h
1R8-E1V voltage is not less than 1.53V when the computer is powered off.
A4h
1R8-E1V voltage is not more than 1.53V when the computer is suspended.
q 2R5-SNS output
Error code
Meaning
B0h
2R5-SNS voltage is more than 3.00V when the computer is powered on or off.
B1h
2R5-SNS voltage is not more than 2.125V when the computer is powered on.
B2h
2R5-SNS voltage is not more than 2.125V when the computer is booting up.
B3h
2R5-SNS voltage is not less than 2.125V when the computer is powered off.
B4h
2R5-SNS voltage is not more than 2.125V when the computer is suspended.
q 1R25-E1V output
Error code
Meaning
C0h
1R25-E1V voltage is more than 1.50V when the computer is powered on or off.
C1h
1R25-E1V voltage is not more than 1.063V when the computer is powered on.
C2h
1R25-E1V voltage is not more than 1.063V when the computer is booting up.
C3h
1R25-E1V voltage is not less than 1.063V when the computer is powered off.
C4h
1R25-E1V voltage is not more than 1.063V when the computer is suspended.
q 2R5-E1V output
Error code
Meaning
D0h
2R5-E1V voltage is more than 3.00V when the computer is powered on or off.
D1h
2R5-E1V voltage is not more than 2.125V when the computer is powered on.
D2h
2R5-E1V voltage is not more than 2.125V when the computer is booting up.
D3h
2R5-E1V voltage is not less than 2.125V when the computer is powered off.
D4h
2R5-E1V voltage is not more than 2.125V when the computer is suspended.
In the case of error code 10h or 12h:
Make sure the AC adaptor cord and AC power cord are firmly plugged into the DC IN 15 V socket and wall outlet. If the cables are connected correctly, connect a new AC adaptor and/or AC power cord, if necessary.
In the case of error code 2Xh:
Make sure the battery pack is correctly installed in the computer. If the battery pack is correctly installed, replace the battery pack with a new one.
If the error still exists, the system board or the battery board may be disconnected or damaged. Disassemble the computer and check the connection between the AC adaptor and the system board and connection between the system board and the battery board (if there is one, in my case it was integrated to ths system board).
After checking the connection, perform the following:
Check 1
Replace the AC adaptor with a new one. If the AC adaptor is still not functioning properly, perform Check 2.
Check 2
Use a multimeter to make sure that the F8800 fuse on the System board is not blown. If the fuse is not blown, go to Check 3. If the fuse is blown, go to Check 6.
Check 3
Use a multimeter to make sure that the F1000 fuse on the Battery board is not blown. If the fuse is not blown, go to Check 4. If the fuse is blown, replace the Battery board with a new one following the instructions in Chapter 4.
Check 4
Make sure that the Battery board cables are firmly connected to PJ8820 and PJ8821 on the System board and to PJ1000 and PJ1001 on the battery board. If they are connected firmly, go to Check 5.
Check 5
The Battery board or System board may be damaged. Replace it with a new one following the instructions in Chapter 4.
I hope this helps many people with the troubleshooting. Details may vary as models vary, but most if it is the same for every Toshiba
Mar 03, 2017 | Toshiba Tecra M10 Notebook
Mitsubishi model Wt-46807 Power shuts down after turning on. Tried the solution of pressing the menu & input buttons at same time for at least 5 seconds. Power light error code was 2 blinks/pause 2...
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Oct 16, 2010 | Mitsubishi WT-46807 46" Rear Projection...
The tv has power but the standy by button is flasshing and we are getting no picture
Flashing standby light is error sign that means TV got problem in its circuits and requires repair.
Model and brand info will help to find out details of flashing error code and please also count how many times standby light blinking.
Aug 12, 2009 | Televison & Video
Error code 2-2
error code 22 means short to ground. for a start check your power supply to see if anything is shorted to the ground.
Oct 14, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
137 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
