Question about Sony KV-35S45 35" TV
How to connect laptop to sony kv-35s45
Do i need converter. I have vga output on laptop and s-video on tv ,i have used the adapter which converts vga to s video but picture is still disturbed with black and white desktop and horizontal line .I cannot see my desktop icons on tv. I would like to know what resolution my crt tv (sony kv-35s45 35") have and will it work or not. I would really apprietiate if someone can help me.
  • rinkle1977 Dec 01, 2008
    yes i have rca input for video on tv but i have only vga on laptop
  • jason May 11, 2010
    do you have another video source hooked up to the tv ? ( yellow rca jack input for video)
    Top Expert:
  • Sony Master
  • 12,962 Answers
When connected to the tv, change the laptop resolution settings until you get one that is satisfactory.
Posted on Aug 23, 2017
techman
  • 3130 Answers
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
  • 395 Answers
SOURCE: Connect Apple TV to Sony 27FS100
the kv27fs100 is a standard 480i resolution check the output of the apple tv make sure it is not in progresive 480P
Posted on Feb 27, 2008
DOCTOR VIDEO
  • 131 Answers
SOURCE: tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
Posted on May 18, 2008
MNfisherman
  • 11896 Answers
SOURCE: Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
Posted on May 05, 2009
yammy_alf
  • 666 Answers
SOURCE: Sony KV-27FS200 bright horizontal line problem
try to replace all filter capacitor on vertical section area that can solve your problem.
Posted on Apr 03, 2010
I want to connect my computer to sony wega triniton kvxr29m80 from the hdmi or vga port to the tv's component or 3rc ports. is it possible..i have tried the hdmi to component cable and it does not...
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
May 11, 2012 | Sony Televison & Video
What cable do I need to connect my Sony vaio VGN FS640 Laptop to my RCA TV and where does this cable connect to, on my laptop? My RCA TV has a SVideo connection.
To output video from your laptop you will need to use VGA out.
What you want to buy is a VGA to S-Video adapter, making sure that both the VGA and S-Video have male connectors.
This solution will not output audio.
Mar 06, 2011 | Sony VAIO VGN-FS640W Notebook
Connect laptop to toshiba 50h8250
This requires a converter. If the laptop has a VGA port, use an VGA to component video or VGA to composite video converter. See this site for some examples: http://www.svideo.com/pctocomponent.html . Do not use a VGA to component video cable - these are meant for projectors that use RGB signals.
If the laptop has an HDMI port, you'll need a different type of converter, like this: http://www.hdtvsupply.com/hdmi-to-component-adapter.html . Then set the output to YPbPr.
I hope this helps.
(I doubt your laptop has a video controller that can output a non-RGB signal.)
Nov 14, 2010 | Toshiba 50H82 50" Rear Projection...
Can this be used as a monitor for a computer?
Hello
Sorry. The answer is you can't. Computers output comes as VGA [Video Graphic Arrey],or AGP [Advanced Graphic Protocol]; and it is not directly compactable with TV inputs. The computer outputs, Red_Green_blue and Horizontal and Vertical synchronisation signals seperatly through one VGA cable which goes into the monitor and there they gets processed and you see the image on computer monitor. Monitors are equipped with such circuits to process the same, whereas in the TVs there are not. Your TV is equiped with S-video connection and not have a VGA input connection.
You must buy a VGA to RGB converter for this purpose. It can be bought from the electronic market, and will have instructions and remote control of its own to control it. You must give the computers signal [VGA], to the input of that converter,with a [VGA to VGA] cable and from which the converter outputs R_G_B [Red_Green_Blue] along with an other output contains synchronisation signal, as described earlier, and will have directions in its manual where should it to be connected. Different converters have different confugurations for this connection, and it will be described in its manual. Ok.
Oct 29, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
No problem, wondering if I'm able to connect this TV to my laptop to connect to the internet and if so what do I need to do this.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
Aug 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
How to connect acer laptop to philips tv to use tv as monitor
If your TV has a VGA input you can connect the laptop using a standard monitor cable. If the TV has component video inputs, you can get an adapter cable with a VGA plug on one end and the appropriate RCA plugs on the other.
Without these inputs, you can't connect the laptop directly. You will need a converter to switch from the computer's VGA output to a standard video signal to feed to the TV. Here is a website with a sample converter. (I don't know this site. It's just one I picked from a Google search as an example.)
Mar 23, 2009 | Philips Televison & Video
Do I need an antenna on my sony model # KV35S45 TV when I cancel my cable?? If so, where is the antenna connection on the TV?? I can't find one. Thanks.
YES! the antenna will plug into the same spot the cable wire is connected too ( you may have to buy a adapter for $1.00 for the the antenna wires to connect to back of your set available at any wall-mart or radio shack) And since your switching to antenna you will need to buy a digatil converter box in FEB to get antenna TV!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Sony KV-35S45 35" TV
Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
Dec 23, 2008 | Dell Inspiron 1501 Notebook
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Sony KV-35S45 35" TV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
