Question about Home
Can I remove an old shower screen myself?
I want to get an old shower screen replaced and am wondering if I could remove the old shower screen myself without specialized tools. The old screen is aluminium and glass with a sliding door and sits on a tile base.
Thanks for your help.
Peter
    Scholar:
  • 132 Answers
Sure peter the sliding should lift out grab a screwdriver and off you go some screws may have covers over them but just be careful you don't push or go leaning on the glass panels to much you don't want go cutting your self it was installed by a person you are a person peter just uninstall it best of luck mate any further questions just ask glenn.........
Posted on Nov 23, 2008
I tried removing my old shower head its severly stuck to the point where even my dad cant remove it. the whole pipe turns when i try to take it out with the wrench and its not working. its really old and...
Hi...you could let the whole pipe come out and replace that too with your new shower head. Just be sure to put some "tape dope" or some plumbers "joint compound" on all threaded connections before install to ensure no leaks especially inside the shower wall.
If you need further help just ask!
over4dy@yahoo.com
Sep 17, 2011 | Home
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
I have the part (Moen 12318). Is there a trick to replacing the old one that appeared to be plugged or frozen closed?
No trick but it does help to have the puller they make to remove the old cartridge...otherwise they are darn near impossible to remove...
heatman101
Aug 18, 2010 | Moen & One Handle Tub & Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also I am wondering what size hex head I need to remove the lever so I can...
i dont know the exact size just get the little set that has a bunch connected when you take handle off make sure water is shut down to pipes then take the inner part out of the center there should be two black screens in the ports where water comes in clean those and should be good to shower
May 08, 2010 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Aug 20, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Triton Silhouette LED temperature fluctuations
Yes this one for the pro's call the company this is not something a most repair plumbers like to do...we would call the company they should know whats going on. If I was on the job thats what I would have to do, and then I would have them ship the parts to me. How old is it?
Feb 01, 2009 | Rubinet 41RBHOBK H2O 1/2 Temperature...
How to Remove Shower Head
Once you've purchased your new shower head the first step in replacing the head is to make sure your shower faucets are firmly turned off and then remove the old shower head. If you look at the existing shower head, you'll notice flat spots on what's called a pipe nipple at the base of the shower head where the head screws into the goose-neck pipe that sticks out of the wall. * Take an adjustable wrench and tighten the wrench onto the base of the shower head flat spots. * Turning counter-clockwise, loosen and remove the old shower head. * Clean the threads on the goose-neck of any debris such as old pipe compound or Teflon tape.
Aug 27, 2008 | Dynasty Hardware Single Handle Shower Only...
Home Logo
881 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
