Question about Samsung Digimax S800 Digital Camera
Outside pictures are all white.
Up until now my Digimax S800 Samsung camera has been great. Although now it takes great photos inside but when I take photos outside they are all white. I have only had the camera for about 4 months. Can anyone help????
    Master:
  • 151 Answers
Do you still have this problem? I think the problem was came from types of image format. please try to set up your camera as a different image quality or size. Otherwise why don't you try to use other memory card?
Posted on May 01, 2014
I've got the same problem as misred. Is there anybody who knows how to solve this problem? Is it the CCD?
Posted on Sep 26, 2007
SOURCE:
I am unable to take photos with my samsung digimax s800 camera as the message 'CARD LOCKED' keeps coming up on screen. I have deleted loads of photos so the memory card is definitely not full. Any ideas?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 17, 2010 | Samsung Digimax S800 Digital Camera
My S800 has been amazing, however since Thursday when I take a pic and zoom in, the image is very bright, or white and has lines all over it (looks like a bad canvass painting, non zoomed images are fine!...
Hi, the problem is in the shutter that you can found inside of the lens unit and maybe the shutter not work properly or damage. you will notice also once you take picture during night time the pictue is good but if you zoom in you will find the lines all over the picture.
tryo to open your camera and check the lens unit. First try to disconnect the the lens cable and connect then check. if the problem still occur, you need to do is open the lens unit and adjust the shutter if working fine or not.also check the flat cable if its not broken.
if you can't do this bring to service center
goodluck and thank you my friend
Jul 17, 2010 | Samsung Digimax S800 Digital Camera
Photos taken outside are all white
Please try to put camera on AUTO in the settings and then see the results. It should give you the desired results.
Jun 04, 2010 | Samsung Digimax S800 Digital Camera
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Samsung digimax s 800 is taking white pictures
'Contamination' would seem to suggest that something got inside the camera and caused a problem - most likely cause, water or some other kind of moisture. Dp you live somewhere humid or do you go to the beach or swim a lot?
Sep 22, 2009 | Samsung Digimax S800 Digital Camera
Samsung s800 white screen problem
It sounds like you might have a faulty camera. I would use the warranty and get it fixed or even replaced. Might be some wrong with the LCD screen .
Oct 16, 2007 | Samsung Digimax S800 Digital Camera
Broken Lcd screen
I have a perfect LCD s800 screen .Camera lens is broken . Dawdle to change if you have a wee star screwdriver..take out the casing screws ..back comes off ..another 4 screws takes the screen out. then the fiddly bit is the ribbon connector..screws back in and fixed . let me know if you want to do a wee deal. Ali
Apr 30, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
168 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
