Question about Canon PowerShot SX100 IS Digital Camera
Lens error,restart camera
When switching on the camera, the lens would not come out, it displays the message "lens error,restart camera" . I have switched it on and off several times, taken out the batteries,replaced with new batteries,taken out the memmoriy card and went through the procces several times
  • 3 more comments
  • mikedebeer Nov 23, 2008
  • Anonymous Nov 27, 2008
    I am having the exact same problem with my Canon PowerShot SX100 IS. I turn on the camera, the blue LCD screen lights up momentarily, beeps several times, then states, "Lens error, restart camera." The lens makes no movement at all. After about 6 seconds, the camera shuts itself off. The camera is less than 1 year old.
  • Rinks73 Dec 15, 2008
  • Fabregas04 Dec 16, 2008
    When I press the power button to turn on the camera the canon blue screen comes on temporarily and then after some beeps a message displays that says: lens error,restart camera. It's so annoying and depressing since the camera is still relatively new? Please help!!!
  • jeffpentz Jan 15, 2009
    Your "pull out the lens and power on" fix worked great! I had to pull harder than I expected, but it worked!.
    Thank you.
    Jef
Take your finger and slide it inside the lens and pull it out slightly, not all the way but enough that it moves. then hit the power button and it should work fine after that. good luck!
Posted on Dec 02, 2008
  • docgoody Dec 24, 2008
    Thanks guys. im glad to have been of great help. Fast, easy, and no money involved :)))
    You welcome guys. Im glad to have been great help. Fast, easy, and no money involved :)))
Was on a cruise and camera lens would not move. Got the same error message "lens error, restart camera. Could not restart camera. Was about to send camera in to be fixed since I purchased extended warranty. However came to this website and found the solution. Thanks so much! It worked great. This is a money saver and nerve saver also. Great! Great! Great!
Posted on Dec 27, 2008
Hi docgoody,
I had just the same problem. Your solution worked out great :D.
Thanks
Posted on Dec 18, 2008
It worked like magic!!
Thank ya.
Posted on Dec 16, 2008
  • Fabregas04 Dec 19, 2008
    docgoody
    Rank: Apprentice
    Rating: 100%, 1 votes
    take
    The above solution posted by docgoody is awesome, it couldn't be better or easier! It is so easy to do but also very accurate. I rate it 5/5 (100%).
    Thanks a lot docgoody!
It worked thank you.
Posted on Dec 09, 2008
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
'Lens error please restart the camera' msg displaying
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 28, 2010 | Canon PowerShot A420 Digital Camera
After inserting lens it keeps saying lens not attached
I would help to know the error message, but here is what I can tell you.
Having a "Lens error " message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
Oct 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Lens error When the camera is switched on the lens does not open out and the lens cover does not open. The camera then displays a "lens error" message and suggests that the camera be restarted ten...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error
yes, this happened to me, what you have to do is "snap" the lens back in place, if it is bent anyway. if it is not bent and it says lens error, does it the lens come in and out? if not then it is bent if so then there is a hardware error in the switch and you will have to send it to a profesionall. :) hope i could be some help :)
Jun 17, 2009 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Error on lens restart camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 20, 2008 | Kodak EasyShare C875 Digital Camera
the beeping sounds means that your camera lens is stuck. contact the manufacturer (canon), for a possible solution...or they can even send u a new one. My friend dropped her SD630 and had the same problem...she contacted canon, and sent in her camera to be fixed, but it wasn't fixable, so canon sent her a brand new camera. hope this helps.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SX100 IS Digital Camera Logo
210 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
