Hi from the Philippines and welcome to FixYa, I am Kelly
Is it just the power whisk or all attachments that do not rotate? On the A701A there is a clutch and spring fitted to the gearbox. (Spring loaded clutch) There is a pin in the cover that actuates the clutch. If the pin is broken or come out of the cover then the front of the machine will not work. (you may have to have someone fabricate a new pin!) If the clutch spring has broken you will experience the symptom you described also.
Hi. I've checked the Kenwood Service website and from what it looks like, A720 mincer is only suitable for A701, A701A, A702, and for Major models A707, A707A, A717.
The mincer specified for the KM800 (from it's owners manual) is the
A950.
Yes its when the attachments have been through a dishwasher it damages the surface. you can still buy new attachments you have to change the shaft from the old attachment to the new one
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Hello . if you want assemble can opener to your A701A the model is : A778
please visit our web site Kenwood Chef Restore in the section download, you find the compatibility of the attachment to download. also Download in the same section the instruction book for A701A models and there explain how you fit the can opener and another's attachments regards
Hi ... all Attachment for models A700D. A701 / A , A702, A703 NOT fit in models A900 ahead anyway, the front of kenwood A900, and KM series its same, you can fit, but not of the models A700/701/702/703C in http://www.kenwoodchefrestore.co.uk you can see the compatibility of attachments Regards
