SanDisk Sansa e250 MP3 Player
Problem for SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player still does not show up when connected to my computer
By chrism on Dec 27, 2006
Thank you Jewel for your suggestion. The MP3 player still does not show up as an extra drive on my computer, and also the MTP device icon is not showing either. I have tried changing the USB mode to MSC but it does not make any difference. Would it be because I don't have a high speed USB hub on my computer?
The suggestion re stopping a song playing has worked so thank you for that.
Solution #1
posted on May 26, 2008
Not Rated)
ThaMp3Doctor
Rank: Guru  SanDisk Expert
Rating: 86%, 4638 votes
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa e250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa e250 MP3 Player
Do you recommend SanDisk Sansa e250 MP3 Player?
Answer
Answer
I can't turn the player on.the circular ring is lit,but no responce.it is sandisk sansa e250 series
Answer
I started playing the default video on the SanDisk Sansa e250 MP3, I tried to exit it or close it,... (More)
Answer
I can't get my MP3 Player to come on. Everything seems to be working fine when I plug it into my... (More)
Answer
my mac mini doesn't see my sandisk sansa e250 when i connect it so i can't import my itunes playlist... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
