DE - LG Washing Machine WFT7012EN
I'm getting this error. I know it deals with Door Error. This is about top door. There is a small metallic strip which got broken & we lost it.
Is it possible to get this as a spare ?
If I get it I can fix the problem
I fixed it by calling the mechanic !!!
Posted on Nov 26, 2008
My lg wf-t1340tp keeps giving me de error,how o i ix it pease
Hello...
This DE error means Door Error i think in your machine door there is a small magnetic lid.. If the lid is broken or its missing from the particular place means the DE will appear. So just change a magnetic lid its just a small amount dont change PCB Board for that issue.
Jan 09, 2018 | LG Washing Machines
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
De , on lg washing machine display?
Its a Door Error. It happens when your door is not closed properly or the side coeners are not clean. It happens even when the rusty part (small magnetic) part is missing from the door then the door does'nt close and gives an error dE. Dont worry get the magnet for the door or you can call the customer service and ask for the engineer to visit you soon. it will cost you around 500-550 rs for the service. Or change the door will cost you around 1000-1500 rs.
Aug 26, 2014 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
My washing machine LG WFT type showing dE error. understand it is door error. I want to know where the door switch is located.
You're correct- 'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor. Both are behind where the door's latch goes requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 19, 2011 | LG WFT1071TP Top Load Washer
My machine lg top loader wf-t7050tp gives me a dE error what does that mean
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
Jan 11, 2011 | Washing Machines
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Code de
de is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
