Question about Dell Inkjet 720 Printer
Dell 720 Printer not printing envelopes.
I only use Word Perfect. The printer was working fine then one day it wouldn't print a #10 envelope, the only type I use. I un-installed and re-installed the software but it still won't print an envelope. It prints regular pages from emails without any problem and documents I tpye on Word Perfect. I don't know what to do? Any help would be appriciated. Thanks, Chuck
I got the printer to print envelopes again. I completely uninstalled the printer, then reinstalled it by simply pluging the USB connection in. After I had first uninstalled it after the envelope problem started I had been using the 720 printer CD to reinstall it, and it still wouldn't print envelopes. I looked for and found the printer installition instructions and saw that I didn't need the CD to install it. (It was causing a software conflict). The Dell 720 Printer came with my Dell Dimension E310 PC new and the printer software was already on the hard drive. All I had to do was plug in the USB cable, and the printer was up and running like new again. Don't forget, if you don't want Dell to monitor your printer use, DO NOT check the box to allow that when it comes up during installation, other wise you'll get that icon showing up. Hope this helps. Chuck
Posted on Jan 23, 2007
SOURCE:
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
We have a Dell A940 Printer. When printing a
check!, what colour is the xter you were hoping to print on the envelope, that you need to confirm from the printer settings, also on the envelope setting
Mar 16, 2010 | Dell A940 All-In-One InkJet Printer
When i print envelope the return address gets cut off
There are some parameters that must be correct before an envelope will print properly. The M/P tray on the KM-3035 should be configured for the proper envelope size, probably COMMERCIAL 10, (but could be another size...need to measure the envelope) and type should be set to ENVELOPE. When printing from the application,i.e. Word or Word Perfect, be sure to select the proper printer and configure the Print Set-up, print direction, size, etc...You will have these options by clicking file and then print from the application print menu.
Dec 07, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
I have a Dell Printer 720 and envelopes won't print.
make sure in the control panel the options are clearly marked for envelope printing
Jun 06, 2009 | Dell Inkjet 720 Printer
Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Oct 13, 2008 | Dell 5210n Laser Printer
Dell 720 only prints red on envelopes
hi!!!
what type of printer ur using?
because the other color of catridge nozzle might have been clog
this are step that you need to do!!!
1.perform maintenance of your printer in the setting
2.clean up the nozzle.
3.remove the cartridge clean with alcohol or solvent use cotton buds.
4.if doesn't print again replace your cardridge.
or email me ronaldsuboc@gmail.com
Sep 18, 2008 | Dell Inkjet 720 Printer
Printing Envelopes
Be sure you have set the PRNIT PREFFERENCES on your program that you are using to print the envelope to accept a #10 envelope and not 8.5x11 paper, you ALSO must set the PRINTER PREFERNECE to MANUAL FEED and not automatic so it won't look to the paper tray.
//CowboysFanZ
Mar 28, 2008 | Dell 3100cn Laser Printer
Dell Inkjet 720 Printer Logo
280 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
