Question about OKI C5200n Laser Printer
Belt Replacement Belt Life is at 18%. Can this item be replaced without taking to service center and are there instructions some place?
Download info from Okidata site.
Posted on Nov 23, 2008
How to change the battery of a Bugatti Vera kettle
The battery is rechargeable.
c) Battery
The battery can be removed and replaced by user because it is placed inside the handle (3). The battery
life is over 2 years. After that period the battery still has 70% capacity. When the display (2) cannot stay ON,
while the kettle (4) is removed from the power base (5), means that the battery has reached its minimum
level capacity.
Contact an authorised Bugatti Customer Service Center in order to change the battery : the service center
will send you the battery pack and its replacement instruction. Attention : remember that the batteries are
consumable parts and they are out of warranty
Vera Bugatti Owner Manual Page 17
Apr 16, 2016 | Kitchen Appliances - Others
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
Asko T702C Service Manual
That is a pretty easy fix without the manual. Take off the top by removing screws on the back top. Remove the sheet metal screws around the perimeter of the the back panel. Pull the drum off the front enough to drop the belt in front of the drum. Put the back panel back on. Now you can thread the belt back into place. The belt runs with the ridges on the spindle of the motor and on the smooth side on the tensioner.
You should replace the pulley idler when replacing the belt, also. I learned this the hard way and snapped a 5 month old belt.
Jan 19, 2014 | Asko Dryers
How do I change the battery on my Macbook Air?
Please take your macbook air to your nearest Apple service center.
Oct 09, 2011 | Apple MacBook Air
I need to replace a cracked deck and worn belt. I need the instructions on how to do these things.
1st take side rails off front hood .you have afront roller and a back roller. for the front take out the two or one bolts holding the the roller in placenow the back roller take out the bolts that hold the roller in place . now on the deck there is 3or 4 screwson each side holding the deck in place. slide w/ belt off put on new deck.install screws, rollers ,bolts.. now center w/belt and adjust tention on w/belt
Feb 28, 2011 | Cardiozone Supersport Hr Club Commercial...
Belt broke
Get a replacement from any appliance parts supply house. Take your old one with you along with your make and model number. Place the belt on the drum, then on the motor pulley. Pull the tensioner past the belt, center the belt and slowly release the pressure to tension the belt. Rotate the drum a few revolutions to make sure that the belt has centered up properly and that the tensioner is working correctly.
Best regards, --W/D--
Jan 24, 2011 | Dryers
How to turn off the timing belt light of a 3L engine
Have you replaced the timing belt? The warning light is a maintenance item that shouldn't be ignored. 60k is the average life span of a timing belt and if ignored and belt breaks you're in full a "wallet full" of repairs. Replace if you haven't, then have Toyota or service place reset the light. That's one light you shouldn't ignore.
Jan 04, 2011 | Toyota Land Cruiser Cars & Trucks
WHILE CHARGING THE LAPTOP IT IS NOT GETTING CHARGED . as well as service centers in mumbai
That is the usual sign that your battery needs replacement. If the battery is over about 18 months old or you either use it a lot and to a low charge state or leave it on the charger most of the time then it has most likely reached its service life.
Can't help you with a source for a new one there.
Apr 20, 2010 | Computers & Internet
Idler pulley replacement?
Once the belt is removed, the center bolt from the idler pulley should unscrew normally with a socket. The replacement pulley bolts back in with the same bolt, then just put the belt back on. The bolt should be very snug, but do not overtighten ir it will shorten the life of the idler. As tight as you can get it with one hand using a typical 3/8" ratchet should be adequate. There should be a belt routing diagram on a sticker under the hood. Belt removal and reinstallation is achieved by using a 3/8" drive ratchet or breaker bar to engage the square hole on the spring loaded tensioner arm and flex it clockwise on most engines. On other GM engines, placing a socket on the center bolt of the tensioner pulley and turning clockwise will flex the tensioner to loosen the belt. When you have the belt off, check all pulleys for smooth rotation and listen for squeaking. If any of them bind or squeak, they should be repaired/replaced as well. Installing a new belt is also a good idea when replacing the idler.
Dec 12, 2009 | 1995 Buick Skylark
My shaver is approximately 3years old and it "bites" me. What do you think it needs? and where can I get help in the Central Coast of California.Thank you.
HI. Have you ever changed the foil or cutter? You'll find a world of difference when you change them. It's recommend you change them every 18 months (as specified on the packet).
Your model is the Syncro which takes a 30B/Series 3 - 7000/4000 Series foil/cutter. You should be able to locate by doing a Google search.
Otherwise try http://www.braun.com/us/consumer-service.html?country=United+States+of+America&continent=am&action=country
Apr 18, 2009 | Braun 7528 Syncro System Automatic...
OKI C5200n Laser Printer Logo
138 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
