I have a new monitor my old one could only do 1280 by 1024 but my new monitor is samsung 2243 bwx and it can do 1680 by 1050 but i dont get a choice in the graphics settings
  • 56 Answers
Most likely the video card does not support this resolution. Contact the video card manufacturers website and take a look at the video output specifications. If it does support the resolution then check and make sure that you have the most recent drivers for the video card.
Posted on Nov 23, 2008
I have pink line at my samsung syncmaster 2243 monitor, can i fix it?
Hmm, probably not. It is likely that the fault is in the video card. Test the Samsung monitor on another PC. If the line is still there then the fault is in the monitor. If not then it;s the video card.
Dec 10, 2013 | Samsung Computers & Internet
Need help to fix Monitor
It broke in transit. There's a connection to the screen broken, and shaking it makes it contact again. The case is held together with snaps, which are a pain to get apart but can be done with thin tools like putty knife or screwdriver. You might be able to find something loose, you might be able to solder it back on or just put some tape on it to keep it connected. You might just chuck it when it drives you crazy.
Apr 08, 2017 | Computers & Internet
My samsung 2243 flicks?
When your screen flickers, go to the desktop, right-click on it, go to screen resolution, advanced settings, go to the monitor tab and change tge screen refresh rate to 60Hertz and tick the box "Hide modes that this monitor cannot display. Click ok and you should be okay. If it doesnt work then its a technical problem. Get a computer technician to fix it up for you.
Dec 13, 2011 | Samsung SyncMaster 2243BWT Monitor
I have a Samsung sync master 943 bwx and when i first set it up my main menus was in some other language how do i get it back to english?
I have tried to find a manual, to see if there is a way to change it, but have not been sucessful.
The languages it supports are: French , Spanish , English , Swedish , Turkish , Italian , Portuguese , Russian , German so it's possible to use google translate to find out which is the option for language.
I know Spanish is Idioma, Swedish is
eitherS PR?K or TUNGOM?, Turkish is dil.
See if you can find that option, and you will probably find "English" or "Ingles" as a sub-option.
Jul 31, 2011 | Computers & Internet
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
You're using dual monitors and one is black? If so-- when you switch the cables on the monitors.. the same monitor stays black? This sounds like bad monitor. If I understand you right.
Feb 10, 2011 | Computers & Internet
Samsung 2243 monitor no screen, power light is on but no image??
u can change the elctrolitic capacitors in power supply it will be 100% solve
Jan 22, 2011 | Samsung 2243BWX Monitor
Syncmaster 2243 bw samsung. Check signal cable message
The monitor is fine, just that it doesn't receives any signal from the video card of the pc. You will have to test it: start by using another video card.
Dec 29, 2010 | Computers & Internet
My samsung syncmaster 943 bwx turn black after few second turn it on.1st i thought is the software change it .but it seems not . I try to solve it since i noe some basic . waw gt many bad capasitor and...
When DC filter caps are bad, the circuits will get AC ripples feeding the inverter output circuits and caused it to run at worng frequency and caused it to over heated, hope fullly it did not take out the MOSFETs.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 20, 2010 | Samsung 943T Monitor
Backlight keeps dimming
More likely to be the power supply or inverter circuits, testing the lamps will be harder without proper tools.
Please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 04, 2010 | Samsung 2243BWX Monitor
Computers & Internet Logo
60 people viewed this question
Alun Cox
David Payne
David Payne
