Question about Philips DVP3345V/17 DVD Player/VCR
No picture or sound-led is on
RE: phillips 32ps55s331
the problem slowly got worse over the last 6 months,
tv would turn off by itself after start up. once tv powered up it would occasionally have a warped and distorted picture. as time went on it required more and more power on attempts just to get a **** picture. once the set warmed up (after 10-15 attempts) it would work fine. Now, when you push the power button, tv or remote, i get the led to light up and thats it. no other signs of life at all.
I would like to troubleshoot and repair myself. I can not find the info i need online. what can i do on a limited budget.
Thanks in advance.
Nick
    Top Expert:
  • Philips Master
  • 45,979 Answers
Probably a defective power supply
Posted on Apr 07, 2017
techman
  • 3130 Answers
SOURCE: philips dvd player not working
Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
Posted on Jun 05, 2006
SOURCE: No power
Brand, and size please? Most problems come from either the power supply, or deflection circuits.
Posted on May 27, 2007
SOURCE: TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Posted on Jun 25, 2007
Kazong
  • 152 Answers
SOURCE: assistant
check your sleep timer settings thats the most comman prob
Posted on Dec 18, 2007
  • 4 Answers
SOURCE: tv does not turn on
Replace C2455 47uf 25V
Posted on Dec 22, 2007
HI - I HAVE SOUND BUT NO PICTURE - COMPLETELY BLACK.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Nov 25, 2017 | Televison & Video
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Phillips 47pfl7403d/f7 picture goes dark and then out completely
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 24, 2017 | Televison & Video
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
43H70 has sound by no picture
also check the horizontal o/p transistor for short if ok ,look on the deflection board and see if there are any b+ voltage markings and test with meter for b+.
Sep 12, 2007 | Toshiba 43H70 43" Rear Projection...
Matsui 42" plasma TV
hi everyone, well i,ve solved our problem. i had the same head bashing problem for months,tried everything.what you have to do is turn all display settings to 0 and then run tv for several hours like that,then slowly bring up brightness and colour only leave contrast at 0. i,ve tested this for a week now and bingo the light show is over at last,my god the relief.good luck everyone
Sep 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips DVP3345V/17 DVD Player/VCR Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
