Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher & Paykel intuitive code 37
Mashine works ok until reaches rinse cycle when pump wont work . Have removed pump for cleaning and found nothing.Pump tested ok on the bench but when fitted to the machine will not work. Pump does "hum" and when you get under machine to investigate can see pump trying to move.When you turn the pump by hand with the machine on can feel some resistance ( magnetic ) but with machine off and unplugged resistance is gone. Even with machine off but still plugged in can still hear pump "hum" and feel resistance. Could a capacitor be gone? HELP!!!!! I have the exact problem, will not pump out water at its last cycle, then beeps with code 37. please help, someone had suggested pump drive circuit board, but how do I get to this? Thanks
  • kst66586 Dec 15, 2008
    pump won't work. When i put it on spin to empty it keeps filling. I have bailed it out but not sure what to do next.
My machine is actually an IW811. But what happened was I checked motor see if it was spinning & confirm it was. But realised instead of pumping water out, it was going back into bowl, went straight to diverter valve, found control solenoid was burnt, was very hot to touch, even though hasn't been operating, only with main power point on. Suspect motor control board faulty as well. Replaced both parts & was fine after that. New contrl board has been upgraded & came with listings of all codes, explaining every code in detail. Specs to test switch, motor & solenoid resistances. But thanks to you guys for pointing me in the right direction, with what code 37 means in the begining.
Posted on Nov 25, 2008
2 Suggested Answers
SOURCE: Fisher & Paykel intuitive code 37
As a serviceman for 18 years I have seen this numerous times.
The fault sounds like the motor control module.. Assuming your test on the pump windings was ok..?
Posted on Nov 21, 2008
Fisher paykel error code 37
check drain pump is not blocked or faulty
Aug 03, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fault code 37
Hello, code 39 is indicating you have an issue with the drain pump. The most common being the pump is failing. If you have been hearing any kind of sqeeking or squeeling or a rattling sound during the wash cycle the pump is failing and will need to be replaced.
Apr 09, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault 37 but pump is clear and does work part of cycle
there is a blocked pressure chamber or switch remove and clean then try again / it is letting to much water in
Jul 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Jul 04, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Nov 12, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
418 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
