Question about Canon PowerShot A60 Digital Camera
Canon a60 viewer streak
Streak shows about midway up across viewer about 1/8" wide obscures view in that area. Pictures are ok. I suspect there's not much to be done unless it gets worse. But maybe... Thanks for your assistance. 72yr old noobe
  • dadams745 Nov 25, 2008
    My wife has a simular problem with her A60 only the whole screen is covered with blurred lines and the picture cannot be made out at all.
    Any suggestions would be greatly appreciated.
    Thanks,
    Denis
  • Anonymous Dec 01, 2008
    Could it be the memory card? I changed batteries 2 times and still got the blurred lines
    Novelist:
  • 150 Answers
This is a definate problem with the viewer. Try replacing the batteries first, otherwise ... you will want to contact Canon technical support and seek repairs by calling the number found on your limited warranty card.
Please mark as FixYa!
Posted on Jan 16, 2009
  • Greg Wright
    Greg Wright Jan 21, 2009
    Thanks for visiting and posting your problem.
    Would you reconsider increasing the rating because a Nice Try is more for solutions that did NOT solve your problem and was off the mark. I'm not sure that was the case here because it's my opinion that the camera problem cannot be fixed without service. So this would be a FixYa. I hope you reconsider the rating and mark it higher.
    To be certain, contact the camera company, see what they say and then rate accordingly. Our expert help here is free and we can use any kudos we can get. Especially if it helped you and was accurate. =) Thanks.
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Brother MFC 8500 print issue
Hi-
Try cleaning the glass part with a glass cleaner solution with a damp cloth, but if you need instruction how to clean the inside part of it, suggesting you consult a technician or certified servicer for the product to avoid further issue. thanks for using Fixya!
Jul 16, 2008 | Brother MFC-8500 All-In-One Laser Printer
Canon c2880 streak across width of 8 1/2 X 14 paper when printed
THE PAPER SELECT ARE NOT COMPATABLE, SELECT LGL IS EQUAL TO 8.5/14 FLSC IS EQUAL TO 8.5 /13. TRY TO SELECT BLACK COLOR OR CLEAN YOUR DEVELOPING UNIT.
Feb 06, 2014 | Canon imageCLASS D880 All-In-One Laser...
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    There's a 2" black streak across the top of every
    check your scanner unit,guide,mirrors,lenses.all mean scanner cavity
    Jan 10, 2011 | Canon NP 6230 Copier
    We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
    Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
    Dec 30, 2010 | Brother Office Equipment & Supplies
    Light streak shows up on display screen after the after the shot.
    I am experiencing the same problem. Upon zooming in the streak gets bigger as well. It does NOT remain static. I need to thry to upload the pictures and see if the streak is there as well. I am trying a complete restart. (IE take lens off and take the battery out for 30 plus minutes
    Jun 06, 2010 | Canon EOS-1Ds Mark II Digital Camera
    Ixus II stripey pictures
    This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
    http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
    http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
    Applicable cameras include:
    A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
    Jan 22, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
    Horizontal streak in screen
    Does it only show up on Cable or does it shows on all Dvd, Cable, Sat, etc ?
    Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
    Canon PowerShot A60 Digital Camera Logo
    79 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
