Question about Quasar SP-3234 TV
A 1/4 in Color line across the center of a black screen
A couple of days ago I turned on my daughter's Quasar Color TV and received a black screen with a 1/4 in horizontal band across the center of the display. The audio was normal and the band was flickering in color.
She had travelled from Washington, D.C. to Reno, NV towing a U-Haul loaded with personal belongings including the TV.
The TV was connected to a Direct TV satellite cable signal via a satellite receiver and A/ V cables. The TV seems to respond to the front-mounted Volume, Channel and TV/Video buttons, but the narrow band is the only video and, except for the flickering, doesn't change.
A primary HD TV and Direct TV receiver from the same satellite in the other room functions properly.
I wonder if the TV is repairable and and wether it is cost effective given the age of the unit (mfg date is June 2001). I live in the Reno, NV area.
  • mazolewski_s Nov 23, 2008
    The original solution response asks me to confirm the product Model WHICH IS: SP-3234E and NOT SP-3243 as reported by your responder.
    Also I would like a specific repair and cost estimate to help me decide wether or not to proceed with the repair.
    I don't understand the response from Solutions by pankaj_dic:
    "this is the power problem check the voltage settings"
    What power Problem & check what voltage settings?
    Also, my requests for specific problem description and estimate of repair costs not answered.
    Please refund my fee, since I am not receiving specifics I requested.
    Novelist:
  • 98 Answers
Sounds to me like there is a strong possibility that the power supply is going out on it. You might consider calling around to get estimates from local TV repair shops. However, you're absolutely right...depending on the size of the TV, what kind of TV it is, and how much it would cost to replace it as opposed to repairing it, you may end up deciding to just let it go and purchasing a new one. I wouldn't make that decision before getting an actual inspection on the set, though.Given the fact that the TV is going on 8 years old, it sounds like you have gotten your money's worth out of it, but it still might not be a lost cause to get it checked out. Hope this helps and have a great day!
Posted on Nov 23, 2008
    Genius:
  • 1,250 Answers
This is the power problem check the voltage settings
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your post describes a vertical deflection failure. This would normally involve a single IC. Pls confirm that you have a Quasar SP-3243 TV unit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 23, 2008
    Thank you for the information that your unit is a Quasar SP-3234E. As originally suspected, the most likely suspect would be the vertical IC. In most versions this would be LA7838 or any of its variations. LA7838 is a small single-inline IC of 7 pins. It would normally be attached to an aluminum heat sink. It is often found relatively close to the flyback. Part cost would be roughly USD10 max. Service fee would depend on the going rate in your are.
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
White line across black screen (setup mode?) model
if line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Jul 03, 2010 | Quasar SP-2725 27" TV
Screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Jun 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Quasar SP-3234 TV Logo
26 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
