I want to install usb-serial cable - Computers & Internet
  • 189 Answers
If you have the cd installer for *********** board there is an option for you to select to install the usd driver if it was not installed.
Have it also detect at the cmos.
thanks
Posted on Nov 23, 2008
Zebra 105sl can't connect to new windows 7 pc
What motherboard is in the computer? USB to serial drivers can be chipset specific.
Apr 01, 2017 | Office Equipment & Supplies
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
I am trying to install the Singer professional Sew-Ware software on my new computer that us running Windows 7, I had to purchase a Serial to USB cord which I attached and installed the cord. When running...
Singer.com's FAQs provide the following:
Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 22, 2010 | Singer Professional Sew Ware Options 2.0...
Need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Jun 30, 2010 | Furuno GP31 GPS Receiver
Do not suceed to print with usb-to-serial cable
use a null cable and is ok.
Diego.
compuzonic.com
Jan 18, 2009 | Epson TM-T88III (C420863)
GPSmap 176 not communicating with laptop via serial/USB adaptor
sounds you do not have appropriate usb driver so find download and install usb driver from following website:
http://www.usb-drivers.com/
chose your compute product to make sure about USB driver.
Nov 11, 2008 | Televison & Video
HP Laser Jet 4 Plus to iBook G4 serial to usb
serial to usb is not plug and play so i don't believe this configuration will ever work.
parrallel to usb is plug and play 90% of the time.
purchasing and installing a port replicator is a 100% fix as long as the formatter on the printer is working properly. good luck!
Aug 21, 2008 | HP LaserJet 4 plus Printer
Xtreme viewsat: I am trying to download this receiver using usb to serial cable but not able to download. Driver installed. Could you help ?
What kind of cable are you using after the USB to serial?
You need to have the NULL cable and make sure that you assign the proper comm port.
Jul 16, 2008 | Televison & Video
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
