Question about Sony KV-32S40 32" TV
Sony KV-32S40 32" TV problem
I have this Sony KV-32s40. its about 5-6 years old and its been working fine until last year. It started off just turning its off while watching the set. So we took it to the repair guy and he let it run all day until it will turn off itself but it never did. So, he said he didnt see the problem. Took it back and it did the samething. took it to the repair guy and he said nothing wrong with it. took it back and been running good until this morning. Now there is No Sound and No picture. But you do here the click noise when u turn it on and the standby red light flashes all the time. What should i do? I opened the back to see if it was dust problem and cleaned it out with those air dust remover cans. Didnt do a thing. What you guys think is the problem?
  • paul2982 Sep 01, 2008
    how do i pulled the board to re-solder it, is there a safe way to discharge the tube? i do have some electronic schooling. but not tv repair. it is doing the same thing, i can hit the side of the tv and it will pop-back on, i do have sound, when it's starts losing picture around 10 to 20% then the picture shuts all the way down, i guess this is some type of shunt to protect the tube, help
    thank you paul2982@yahoo.com
Somewhere a repair man answered that he recently re-soldered the vertical output IC points - but that problem TV only lacked picture and DID have sound
Posted on Jun 04, 2008
I have a KV-32S40; it also has no picture, no sound, and the red light also flashes.
I called a local service man - he claimed that the nonstop flashing light indicated a bad tube.
Posted on May 20, 2008
    Scholar:
  • 119 Answers
Intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Posted on Dec 27, 2006
2 Suggested Answers
  • 8457 Answers
SOURCE: Standby light blinks continualy and there is no
Ur high voltage is dead.FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to a CRT(tv tube).
Posted on Nov 13, 2009
I have a ten year old 37" Sony XBR TV that works fine until you turn it off and then go to turn it back on. The picture does not come back, but sound does. The only way to solve this is leave it off...
most likely it needs repiars, (replacement of capacitors in the power-supply.)primary and secondary side.
Or loose conections (dry joints)
Apr 20, 2011 | Sony KV-27V22 TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Won't ruen on
nombre de ligne
Jun 17, 2008 | Sony KV-35V35 TV
Sony tv snow for first 5 minutes on
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Sony KV-32S40 32" TV Logo
197 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
