I cannot get any display when i turn on my computer
  • 56 Answers
Check These...
Is the monitor plugged into a good wall outlet?
Is the video cable from the Monitor plugged into the video card on the computer?
Turn on the switch on the monitor to turn it on.
Turn on the computer. Does the computer make any noise or the lights light up like it is running?
IF YES CONTINUE! The computer has a problem, not the monitor!
Is the monitor working? If not then try another monitor. If that doesn't work then you most likely have a video card problem.
Posted on Nov 23, 2008
    Genius:
  • 1,250 Answers
Take out the RAM then put it again, then check
DS-1900S DoubleSight Displays keep shutting off
Sometime the cross-talk of signals causes this. Separate the wiring behind the computer. No touching, no problems.
Mar 06, 2014 | DoubleSight Displays - DoubleSight...
Computer screen on, Projector off
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Jul 09, 2013 | ViewSonic Office Equipment & Supplies
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
When i connect my projector to computer correctly it says no signal
Please perform thebelow steps :
You may follow these steps to connect the notebook to an Projector
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
Projector
May 20, 2010 | Computers & Internet
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
I turned on my computer this morning. The display
press and hold ctrl and alt key at the same time then press left and right arrow key until you get the correct display.
May 03, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
No signal to monitor. Cable is fine and so is the Video Card -
your motherboard may be going out is your keyboard also acting crazy
Aug 15, 2009 | Impression Products Impression 7LSP 17"...
THE COMPUTER IS IN A POWER SAVING MODE
I think you mean, your display is in power saving mode, this happens when there is no signal from the computer - the display then goes to powersaving mode, try restarting your computer, if it doesn't turn on the display. try the display on another computer to see if your display works.
if your display works with anohter computer, try it again on the problem machine, if its still in the power saving mode, then its not turning on, the computer is not turning on-
I would suggest to get a local friend or a tech to look into your computer and find the issue, if your handy with screwdrivers and know your way inside the computer, then you could take the case open and reseat the memory. try without any memory, then try with just one memory module. Then put them all back in, if this doesn't help, its not a memory related problem.
to save time i recommend you take the computer to a local professional.
Jul 15, 2009 | LG L1915S 19" LCD Monitor
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
