SanDisk Sansa m240  MP3 Player
Problem for SanDisk Sansa m240 (1 GB) MP3 Player
Freezing
By Lisa B on Dec 27, 2006
My MP3 player (Sandisk Sansa m240) has gotten stuck on a message that says "Please wait Rebuilding the library" its been like this for some hours so i know its frozen. someone help please ASAP!
Same Problem
Jul 08, 2008
-   i added songs from a laptop that has windows vista. the first time i put music on my mp3 player, it was done on windows xp. it's been frozen ever since i tried downloading music from vista. My mp3 player says "please wait, rebuilding library. tried removing the battery, putting a new battery in, connecting it to windows xp and holding the start button down for about 2 minutes, etc but still can't get it to work.-   mconroy63
Jul 02, 2008
-   freezes up and says rebuilding library-   timenough37
Feb 10, 2008
-   My MP3 player (Sandisk Sansa m240) has gotten stuck on a message that says "SANSA" FIRST MENU AND NONE OF THE BUTTON WORKS AFTER THAT ECEPPT POWER OFF. someone help please ASAP!-   Hamid54
Best Solution
posted on Jan 08, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same here. Our is stuck on "voice record" mode.
Does anyone have the number for Sansa Customer Service?
Off to google ...
Solution #2
posted on Jan 03, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with mine, contacted Tech Support at Sandisk and they sent me the same response that this last guy posted. I did it all and it worked for a day and then the same problem and I barely had 1/2 the memory used up. Contacted Sandisk again and they are sending me a new one - I did not buy mine from Sandisk. Maybe there was a batch of duds or something. Anyway, I would contact them - maybe they'll replace it for you.
Solution #3
posted on Jan 01, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line.
We do apologize for any kind inconvenience this issue is causing you.
For verification, does your computer have Windows XP as its operating system?
This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution.
Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding.
If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer.
Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer.
To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again.
We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data.
Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears.
After formatting the Sansa m240, please do try your Sansa m240.
If applicable, please go the link below to download the firmware update for your Sansa m240. The link is:
http://www.sandisk.com/Retail/Default.as... or http://www.sandisk.com/Retail/Default.as...
If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer.
NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Solution #4
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had same problem, contacted Sandisk and did all the stuff in the last guy's post. Wroked for about a day and then the same thing. I didn't even have 1/2 the memory full. Contacted Sandisk Tech Support again and gave them model#/serial# info for my unit and they are sending me a new one. (I didn't even buy it directly from them). Maybe there were a bunch of duds - even Consmer Reports gave these things a decent rating! I'd contact Sandisk if I were you.
Popular Solutions for SanDisk Sansa m240 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa m240 MP3 Player
Do you recommend SanDisk Sansa m240 (1 GB) MP3 Player?
Answer
Answer
how do i take music off and put new music in, it doesnt show all of the music files either?
Answer
i can't delet my curent playlist so that i may add anew
Answer
i am having sandisk 1GB ipod, whenever i switch on the ipod the lock symbol is coming afterwards no... (More)
Answer
I pushed the format button and now my music is erased and i can not get music from my computer to my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa m240 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 384
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
