Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Fridg not cold
The refridg only blows cold air when the freezer door is open..
  • ripfe Apr 29, 2008
    my problem is the same , the compressor never stop and clough the air flow to the fridge. were are the parts i need to change mine have a digital control panel in the fridge is a kenmore 106.5657... somthing like that
  • Anonymous Mar 13, 2014
    cold air doent enter fridge when freezer door closed
  • 237 Answers
Ahhhh, the classic symptom of a frozen coil/air return duct. You'll have to pull the back panel off the freezer wall to view the coils. The are likely a block of ice causing the air channels on the sides to be frozen, thus blocking air flow. You may need a defrost t-stat or a defrost timer. If the defrost cycle isn't working then you will get a freeze up eventually. The only other reason is if the freezer door was left open slightly overnight letting in moist air. Let us know what you find.
Posted on Dec 27, 2006
3 Suggested Answers
  • 958 Answers
SOURCE: fridg not cold
your story is very odd but likely nobody is messing with the door switch hwen you moved , or the wires could have shorted out. normally, the door switch, when you open a door would switch on a cabinet light and turn off the blower. in your case, its the reverse, as you open a door, the blower runs and if you close the door, the blower stops. im not sure if you can figure out which pair is the normally close and which one is the normally open on the door switch in order to swap them or you may rplace the door switch.
Posted on Feb 05, 2008
woodchuck789
  • 4070 Answers
SOURCE: Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Posted on Aug 22, 2009
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
I have the refrig where the freezer is on the bottom, the bottom is working fine but the top is not getting cool.
a common problem with bottom mount freezers is the door gets left open,open the freezer door and look at the ceiling,is there ice on it and is there also frozen water droplets on the packages,if so the door was left open,you can shut the fridge down or unplug it,remove the food from the freezer,get a hair dryer and blow the hot air onto the back inside wall of the freezer mostly blow it into the open slots in the back wall,it will melt the ice that's in the air ducts,you'll see water dripping down,when it stops you can start the fridge and stick your hand in the top middle of the fridge section to feel if cold air is blowing in,all that it does is there's a fan in the freezer,all it does is blow the cold air from the freezer into the fridge section,if the door was open the warm air gets in and mixes with the cold air and it freezes up the air ducts and blocking them.if this isn't the problem open the freezer door,you should hear the fan blowing,if not you could have a bad fan motor,also put your hand on the back inside wall of the freezer,if there's like frost or snow on the back wall you have a defrost problem,a bad defrost heater,defrost thermostat or timer or board depending what the model is,but most of the time the problem is behind the freezer inside wall,or depending on your model there could be a damper in the fridge section,if it's stuck closed then the cold air won't blow into the fridge section.so first open the freezer door,listen for the fan,if it's blowing,check for frozen water droplets and ice up on the ceiling near the light and on the food packages,if you see this the door was left open,if the fan isn't blowing most likely it could be bad,then check the back inside wall for frost or snow on it,if there's frost on the back wall you have a defrost problem,most likely it will be a bad defrost thermostat or heater,you'll need to check them with a maeter,hope this helps,next time send the model number so i can look up your machine.
Sep 04, 2011 | Maytag Refrigerators
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
Fridge compartment is not cold enough
inside the back of your freezer there are two holes that lead to your refrige there is also a fan with a small motor attached is the fan blowing the air fromthe freezer into the refridge section also are the two holes plugged up with ice these are some of the first things that you should be checking turning that switch basicly jut opens the damper door that goes fromthe freezer to the fridge so in allactuality if the door is pluged with ice or the air isnt being pushed through those holes your refridge wont get that cold also another thing to check would be the operation of that small damper door if you do have a fan runnning and do not have ice but if the door is always closed this could also cause this problem hope this helps
Jul 16, 2010 | Hoover HDA452 Top Freezer Refrigerator
FREezer works fine,frig will not go less than 40 degrees and unit never cuts off
the problem is the freezer drain is plugged up. when the fridge goes into defrost,the water that is suppose to drain out has no where to go. so it refreezes . that ice has plugged up the blend air vents between the freezer & the fridge.
1st put your food in a cooler. Unplug the refridge.
(you may want to take pictures as you go.for the reassembling)
open up the freezer, remove the rear panel, & the bottom panel (if possible)
you will see the coils, underneith the coils you will see an metal tray. it will probly have ice on it.
with a blow dryer, heat the ice till you see the drain . now that drain has to be cleaned out.
that drain runs down to the bottom of refridge into a drain pan. with a wet vac , attach it to the drain tube, until you fell suction in the freezer. small amounts of hot water does help.
( it usually gets plugged up from bugs)
next , open the fridge ,on the ceiling of the fridge.there will be a plastic cover (most models) remove the cover carefully. usually there are 2 passiges from the freezer to the fridge. that is where the cold air drops into the fridge. there will probally be ice in these passages, which has to be removed.(be careful with the stirofoam)
once you have cleaned out all the ice ,reinstall all those pieces.
plug back in the refridge.It will tak a day for it to get cold again.( hint get 2 bags of ice to help speed up the cooling down process)
Apr 27, 2009 | Refrigerators
Fridg not cold
Feb 05, 2008 | Refrigerators
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
319 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
