SanDisk Sansa m240  MP3 Player
Problem for SanDisk Sansa m240 (1 GB) MP3 Player
My sansa M240 WonT turn on all the way
By Ladii Ace on Dec 27, 2006
My Sansa M240 was working fine and outta no where it turned off i tried to turn it back on and it would just freeze on the Sansa logo i tried taking out the battery and i tried reseting it and nothing works i dont know whats wrong...
Clarification Request
Posted by applefruit13 on Jan 27, 2008
my m240 is froze and i can't fix it this is my 2nd one, i had another one and it did the same thing i am never getting this mp3 player again!
Same Problem
Apr 09, 2009
-   my sansadisk m240 is frezed system not recognizing and when i switch on the sansa its shows its logo and gets freezed it will not repond how i can i get rid of this prob-   sundown18
Sep 30, 2008
-   My Sansa does EXACTLY the same thing! It goes to the intital Sansa logo/screen, and then no further. And it won't turn off! I have to take the battery back out to get it to turn off.
Up until now, it's worked perfectly ....
I miss my bedtime music!
Rebel250-   Rebel250
Sep 22, 2008
-   I have the same exacti problem as all of you, but I cannot find a customer service number to call SanDisk. Can anyone provide this number? Thanks much.-   smgdhm
Sep 18, 2008
-   My sansa would turn on to the sansdisk screen then turn off please help Its not the battery they are new. -   qanita22
Aug 30, 2008
-   my moms mp3 player that is the sansa is not turning on when it was working fine befor she turned it off.
how do i get this to work???
-   Guest
Best Solution
posted on Sep 15, 2008
Very Helpful)
vash99smith
Rank: Apprentice
Rating: 95%, 3 votes
Was this helpful?
Yes
No
Solution #2
posted on May 16, 2007
Helpful)
Jester5ive
Rank: Apprentice
Rating: 87%, 28 votes
Jan 21, 07
I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Was this helpful?
Yes
No
Solution #3
posted on Jan 01, 2007
Helpful)
sneller
Rank: Apprentice
Rating: 85%, 5 votes
my has the same freaking problem and it making me so freaking mad! I turned it off and about an hour later i tried to turn it on and i keeps freezing on the sansa logo! gah i am so mad
Was this helpful?
Yes
No
Solution #4
posted on Dec 27, 2006
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same thing happened to us within the first 3-4 hours of using it, it locked up. We took it back and got another model after seeing the trouble people like you .. and I had.
Solution #5
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My response from SanDisk... it didn't fix my problem, but may help you all.
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line.
We do apologize for any kind inconvenience this issue is causing you.
For verification, does your computer have Windows XP as its operating system?
This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution.
Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding.
If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer.
Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer.
To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again.
We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data.
Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears.
After formatting the Sansa m240, please do try your Sansa m240.
If applicable, please go the link below to download the firmware update for your Sansa m240. The link is:
http://www.sandisk.com/Retail/Default.as... or http://www.sandisk.com/Retail/Default.as...
If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer.
NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Solution #6
posted on Dec 29, 2006
Somewhat Helpful)
fruit loop
Rank: Apprentice
Rating: 78%, 8 votes
same here i got mine on my -day and now its doing the same thing as u thats why im taking it back and getting a new one from circuit city
Was this helpful?
Yes
No
Solution #7
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same here after 4 days of use. Had about 700MB of MP3s installed. Powers on from power button or when attached to computer but freezes on SANSA screen. Computer doesn't see the player.
Solution #8
posted on Dec 28, 2006
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same here. Worked fine at first, then locked up on the Sansa Logo upon turning on. Hope I have the receipt. Should have gotten an IPOD! I guess you DO get what you pay for!!
Solution #9
posted on Dec 30, 2006
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My 10 yr old step son's m240 worked for a day then developed the same problem stated above. I've taken the batteries out, pushed every combination of buttons possible, etc. It goes back with plans for a replacement Xmas present.
Solution #10
Somewhat Helpful)
Donzo
Rank: Apprentice
Rating: 80%, 2 votes
Same problem after two days. Tried taking battery out and holding down power button for several minutes. No luck. She's going back to Wal-Mart tomorrow. Daughter has had one for a couple of months with no problem, though.
Was this helpful?
Yes
No
Solution #11
posted on Dec 31, 2006
Somewhat Helpful)
mom4martin
Rank: Apprentice
Rating: 60%, 2 votes
Well, we have the same situation with my daughter's new player. Guess the company needs to do a little work! Looks like there is no fix for the problem.
Was this helpful?
Yes
No
Solution #12
posted on Jun 13, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Freakin hell ......im all the way in India.....dont even know if i can have it returned ......stupid SanDisk people......stupid Mp3 player...DARN IT ..... DAMN YOU SANDISK for making my life so miserable ....
Solution #13
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
it freezes when it says sansa
Solution #14
posted on Nov 16, 2008
Not Rated)
oskary2k_5
Rank: Apprentice
Rating: 0%, 0 votes
my sansa m240 was working fine yesterday and I turn it off normally but when I tried to turn it on today it didn't
but when i connect it to the computer it do recognize it, the only problem is the power button
Was this helpful?
Yes
No
Solution #15
posted on Oct 07, 2008
Not Rated)
speed20
Rank: Apprentice
Rating: 0%, 0 votes
The m240 that i use has frozen on the sansa start up screen and will not boot, it can be turned off but when trying to restart it just goes to the sansa logo .
Was this helpful?
Yes
No
Solution #16
posted on Sep 29, 2008
Not Rated)
walkergirl9
Rank: Apprentice
Rating: 0%, 0 votes
my solution is my mp3 player freze up and i tried to take out battery out and do it again but it do not work
Was this helpful?
Yes
No
Solution #17
posted on May 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem. Sandisk wanted to rma but I couldn't find my receipt. I took out the battery and plugged it in the usb. After about 20 minutes it connected. I tried many things but what finally worked was going to My Computer, right clicking on the Sansa M240 and reformatting.
Everything works. I put on new files and am good again.
Solution #18
posted on Jul 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just go to sandisk.com and get a RMA. They paid for my shipping with UPS and sent me a brand new one. The new one has worked fine I believe it was a problem from units distributed in Dec of 2006.
Solution #19
posted on Jul 03, 2007
Not Rated)
OSUCHARGER
Rank: Apprentice
Rating: 0%, 0 votes
Solution #3 worked for me, but I didn't have to format the MP3 disk. I started it in HOLD mode with my USB cord plugged into an XP computer. (I made a backup of the songs to a folder on my computer, but not sure if I needed to.) When I unplugged the USB port it said 'please wait, rebuilding the library'. Once it was done I took it out of HOLD mode and it worked like it should.
Was this helpful?
Yes
No
Solution #20
posted on Jun 28, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I purchased 2 and sent them over seas as gifts at christmas and they froze. I picked them up when i went over seas several months later and returned them to sansa. They replaced them -- so far no issues.
Solution #21
posted on Jun 22, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
SOLUTION NUMBER 3 WORKED FOR ME!
THANKS YOU VERY MUCH!
Solution #22
posted on May 22, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is my SECOND one... and its doing the SAME thing!! i'm really mad! i got the first one for christmas 2006 and it worked fine for a week then it froze and i brought it back to wal-mart and they exchanged it. NOW, i dont have a reciept or all the accessories it came with... they better let me return it. i saw online that they are now about $49 or so and my parents paid $90 for it. well off to the store...
i feel your pain
Solution #23
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
From everything I've found, you (and I) have two choices- return it and get a different model/manufacturer or pull out the glue gun and make a tie tack out of it. I got my money back and am now researching which player to get.
Donzo
Solution #24
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It's a nasty software bug - I highly suggestion going to Sansa's website and registering a support case. It takes about ten minutes.
Although I haven't rec'd a reply yet - if I don't by Monday noon - it goes back to BestBuy for a refund. I had a feeling a bargin MP3 players was going to bite me later.
I spent 3 hours in line at best buy for this too... that makes it a double wammy. :(
Popular Solutions for SanDisk Sansa m240 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa m240 MP3 Player
Do you recommend SanDisk Sansa m240 (1 GB) MP3 Player?
Answer
Answer
I pushed the format button and now my music is erased and i can not get music from my computer to my... (More)
Answer
I had problems with my computer so I had our IT guy wipe it all and I am just getting around to... (More)
Answer
y does different lettering come up and fills up ur mp3
14 Other Users Have The Same Problem - Continued
Comment by Boomie24, posted on Jun 22, 2008
My mp3 player does the same thing, it turns to the Sansa logo and won't do anything else.
Comment by stacyrules14, posted on Jun 21, 2008
it was working fine . but them when i tried turning it back on it wouldnt turn on. i took out the battery but it still wouldnt work.
Comment by outabout, posted on Jun 11, 2008
Was working fine. Turned it off. Went to turn it back on. BLANK screen. Nothing. Tried hooking it up with the USB cable and no screen. Left it and the Sansa MP2 got hot to the touch. Circle lights up blue but nothing on screen. Can't find manual and have no clue which model this is. Thanks.
Comment by bullpitt1130, posted on Jun 08, 2008
tried looking for drivers restore files but can't find anything
Comment by ah8519, posted on May 10, 2008
What is the phone number for the company that you called?
Comment by lmt1, posted on Feb 10, 2008
my sansa m240 mp3 player turns on but cant play music ,go to menu , wont conect to usb also
Comment by jay09, posted on Dec 25, 2007
hi i have a sansa e200 and it was working fine and then it froze. the screen is white and i cant do anything with it. i need help.
Comment by kneel2, posted on Dec 23, 2007
exact same problem - and this is on a REPLACEMENT unit
oh well, i guess i'll open another issue w/ SanDisk...sigh
Comment by Guest, posted on Dec 20, 2007
When I try to turn on my sansa m240 it lights up, goes to the startup screen and does nothing more. I'm sooo frusturated!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa m240 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 477
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
