Question about Acer Computers & Internet
Acer aspire 6920. needs to be reset back to factory settings
  • Ricky Ostrom
    Ricky Ostrom May 11, 2010
    While starting press the F2 or F12 key and see if you have a System Recovery option.
    Genius:
  • Acer Master
  • 1,250 Answers
Use a recovery cd/ dvd if you have , boot your system to this cd then follow the instructions
Posted on Nov 23, 2008
Hi i reset my acer aspire 6920 to factory settings as the system was running very slow and i could not find the problem...but now i have a worse one.... once it does the factory restore by pressing alt f10...
Sorry to hear about your problem.
The only other way to resolve this issue is going to with the use of recovery media.
Currently you're using the built in partition, but i'm hoping you also made some disks like it would've asked you to.
If so, insert disk 1 and restart to load from the recovery disc.
If not - you can contact Acer to be supplied with these, they'll still be a lot cheaper than buying Windows, but will cost approx $50.
Apr 26, 2011 | Acer Aspire 6920 Notebook PC
Reset acer aspire one d255
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.This will RESET the computer to its Factory Settings( DATA LOSS )
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Oct 21, 2010 | Acer Aspire 6920 Notebook PC
I bought the Acer 6920 factory restore CD's to set it back to factory default but when i run it it gets to the third disk at 90% and then says Restore Failed and gives me this Error code 0xd000000a. Does...
It stands to reason that if it ran the other 2 it should run all of them. that tells me its probably not your system. The disk could be faulty. I would check with manufactuer.
Apr 05, 2010 | Acer Aspire 6920 Notebook PC
How to boot my laptop to its factory setting. its an acer 6920 n it has vista
Take a closer look at the boot up time to find something like
F9 to restore
and press that key during boot up. CAUTION you will loose all your data, so take back-up of your files and write down your passwords and other settings.
Stelios.
Feb 21, 2010 | Acer Aspire 6920 Notebook PC
I have an acer aspire 6920 laptop and i am trying to do a system restore but not have a disc, wat can i do
Reboot the system and on restart press the F8 key to access the advanced system options. Select repair my computer to start the system recovery partition.
This option will restore the system to factory settings and some files or programs will have to be reloaded.
Oct 31, 2009 | Acer Aspire 6920-6422 Notebook
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Passwords
you can try to remove the battery from the motherboard this usually resets passwords.
May 11, 2009 | Acer Aspire 6920-6621 Notebook
To capture video acer aspire 6920 acer crystal eye webcam builti
you need to download a video capturing device
if your system did not come with one
the built in webcam is exactly that for messaging programs and taking snaps but they can be used for video and this is usually something you need to get on your own
debut is usually a pretty good site
please don't forget to rate me
Feb 07, 2009 | Acer Aspire 6920 Notebook PC
Computers & Internet Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
