Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
Unable to format pc
By sunilkumar19 on Nov 23, 2008
i am working in pc and it got shutdown automatically. I have installed 2 xp and vista, now when i m trying to restart the pc it got to the window selection page and when i select the xp it restarting and when i select the vista it showing that there is problem to load the winxp in C:windowsystems32.
even when i try to load from xp cd the page open till setup configuration and it is getting shutdown. the same problem is with vista.
if somehow the setup wil reach the page where we can format the drive for fresh installation then i can able to load the xp but the pc restart before that.
it is urgent pls suggest some step
Best Solution
posted on Nov 23, 2008
Very Helpful)
mayankv
Rank: Master
Rating: 79%, 11 votes
If is restarts without any error...
it could be a virus
Full system format using third party software recommended.
you possibly have hardware problem.
-CPU heating or fan Fault
-SMPS problems
and lastly HDD problems..
visit a specialist to get them checked.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
worldvet
Rank: Guru
Rating: 91%, 846 votes
This appears to be a problem with your hard drive and cross linked files or corrupted security descriptors or it could a combination of several and even the result of a virus you aquired.
When you boot with the XP CD, choose the Repair option as it comes up at the bottom of the window. I think its F8 or F5, I can't fully recall at the moment. But look for the prompt in the white highlighted area of the bottom screen as your machine boots up from the CD. Wait until you are finally in the Repair Command Window.
Now, what you want to do is a few things, but first you must check the integrity of your hard drive. At any time, even when you first get into this mode type: "help" without the quotes. You will see a list of commands, you'll have to press spacebar to see a second page of help commands.
In this list, take note of 'chkdsk', you may type "help /chkdsk" without the quotes and you will get detail on variations on entering this command in this repair mode.
However, type this as I have written it below, I won't use quotes this time.
chkdsk /r /x
This commands Windows to check the integrity of your drive and fix bad blocks and lock the drive for the action of this action only.
If you get an error message, you have not formatted your drive for NTFS, but FAT32 (which is probably why you have the problems, should this be the case.). Instead of chkdsk type: scandisk and let that program check your drive. Allow the programs, chkdsk or scandisk to run their tests and then reboot your computer without the CD in the drive.
As you computer restarts press F8 as if tapping a piano key, you will get a boot source choice screen, CD, Floppy, C OR you will get the Safe Mode boot options menu. If you get the boot source screen, tap escape and immediately, immediately press F8 thereafter, and you will get the Safe Mode boot screen. The purpose here is to boot into Safe Mode. There are a lot of reasons just to do this and then shut down that will take too long to explain here. But booting into Safe Mode and then shutting down will repair a lot of problems. Make a note of that for later. At this point with your computer the need is the same, but you will want to get into Safe Mode for XP, as you're prompted for which OS to boot, XP or Vista, in your case. Choose, XP. Once in the Safe Mode Desktop, go to Start Menu, Programs, Accessories, System Tools, and there is an entry there for System Restore. Run System Restore and attempt to restore your computer to a date prior to this problem starting on your computer. If you can't or it fails, go back to my instructions to starting the Repair Console with your Windows CD and this time type format and choose NTFS.
If however, you find you have formatted your drive before as FAT32, and do get to System Restore and it succeeds, then let me know and I'll explain later how to convert your comptuer to NTFS from FAT32.
Any questions along the way, or now, use the comment text box below to ask away.
Regards,
Worldvet
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
i have installed drivers for ritmo pci 7.1 sound card for win vista but still i cannot get any sound
Answer
how do you get free chips with the bot for the zynga poker on facebook? am stumped
Answer
How do I clear the constant registration reminder for microsoft office 2007?
Describe your Operating Systems problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in Boardman, OH
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
