On my kenmore washer, there is an error loc message. model 44082
It is a front loader. the door opens but i cannot press anything else. i cannot wash my clothes.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Look closely at the control panel there is a button marked "control lock" push and hold for 3 secs it will reset, its a child lock out, youll be fine!
Posted on Nov 23, 2008
The above solution worked for me perfectly. Just note that to do the child lockout reset, you need to press the options and select buttons together for a few seconds.
Posted on Jun 05, 2009
Its says control locked and none of the buttons will work on the front loader. thanks, Rita
Let me find my notes:
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Apr 01, 2011 | Kenmore 4292x Front Load Washer
Where do I find the serial number/ model number on my front loader?
If this is a Kenmore front loader, the serial number is on a nameplate tag around the door opening along with the model number. You need to open the door to see it. I hope this helps you.
Feb 04, 2010 | Kenmore 44072 Front Load Washer
My front load Kenmore washer 44082 does not start. just buzzes and displays ERR.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 04, 2009 | Kenmore 44042 Front Load Washer
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loader - LOC & Error Codes
You need to switch the machine off at the wall and leave it off for a few seconds. Open the door. Switch the machine back on again and close the door firmly. It should be o.k.
Aug 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
