Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
I need the schematics for t5026 emachine
I need to know were the hdd led the power led and the power sw. goes
  • Anonymous Jan 24, 2009
    i need to see how the power supply hooks up
  • 395 Answers
This is intel Desktop Board D915GAG
the manual is at http://download.intel.com/support/motherboards/desktop/sb/c6413602_en.pdf
page 44 has where the connectors go
Posted on Nov 26, 2008
Looking for the front panel wiring diagram for a emachine T4510. The Power LED & the Power SW are disconnected! HDD LED was never unplugged! I need to know where they need to be!
If you look closely at the board there should be labels printed. The power switch plug can plug in either direction, but the LED must be the correct direction for it to work. No damage can be done by plugging the LED in backwards.
Jan 30, 2011 | E-Machines eMachines Desktop PC
Have a t2460 need to know where power sw, hdd led, and power led go on the board.
looking into the PC, lower right corner of the motherboard. You can find a manual at emachines.com as to exactly which place the plugs go.
Jan 28, 2010 | E-Machines eMachines Desktop PC
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
I need a schematic for a d2823 desktop
pwr (power) goes to the on/off switch (led) goes to the light (light emitting diode) hdd goes to the harddrive (hard drive device)
May 03, 2009 | E-Machines eMachines Desktop PC
I need to know what colored wires go where on my customers PC hdd led/ power sw/ and power led
the only reason to have removed them was to switch the board or put the board in a new case..if you put a new board the new board is what you have to go by, look in the book, or take the number off the motherboard and go to yahoo and type in schematic for xxxxx board.
DO NOT go by emachine model as its worthless, too many models have different hardware.
This is all basic repair 101, how do you have customers? lol
Apr 24, 2009 | E-Machines W4685 PC Desktop
Need schematics for front panel , power sw , pwr led , hdd led et
Try this link to Emachines page. After you put in the make and model and stuff you should be able to view the user manual for your machine. If this isn't what you need you are able to contact support from this page and maybe they can direct you to a more detailed explanation that may help more.
eMachines use specially-made boards for them so there is no manual as such as the boards aren't made to be distributed. Basically they would all use the same sort of connectors and blocks (and cases) to an extent that anybody can plug a connector into the right place and it will work.
The easy way to get round this is to find the power button first - try each two pin connector first, press the button and see if it comes on. If not, move along on the block until you find the right one. Then it's just a case of trial-and-error on the other ones to find reset, power LED and HDD led.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W4065
Mar 15, 2009 | E-Machines eMachines Desktop PC
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Need help bigtime
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Mar 24, 2008 | E-Machines eMachines Desktop PC
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
455 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
