Question about Toshiba Satellite A45-S150 Notebook
Screen comes on then goes back off.i hooked to another screen it
Says cmos not right or battery low what can i do
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
After power on the mobo screen comes up, then a screen that says NO DRIVE ATTACHED TO FASTTRAC CONTROLLER, THE BIOS IS NOT INSTALLED.Then it goes to a screen that says PCI device listing, at the bottom of...
Assuming you have a drive connected properly you may want to disable the SATA drive controller in the BIOS, the message is failure to load BIOS from controller. You may also want to reset the BIOS by removing power cable and the CMOS battery for a minute or two, power on, power off and then replace the CMOS battery and power back on. SHould reset BIOS,
Feb 11, 2018 | ASUS P4S8X Motherboard
My dell dimension 2400 will not boot up. It goes to a black screen and displays either keyboard failure or F1 or F2 options
This can usually be solved by resetting the CMOS.
Unplug the power from the back of the tower. Open the side of your case and locate the round battery near the lower-right side of the main board. Pop the battery out. Just below it you should see 2 little gold colored pins sticking up. Right around it it should say 'Clear CMOS' in very fine print. Take a small screwdriver and hold it to the two pins so they are shorted or touching each other through the screwdriver for a few seconds. Place the battery back in the machine and see if this works.
Oct 22, 2009 | Dell Dimension 2400 PC Desktop
I have a compaq armada but dont know the power on password how can i fix
Try this remove the main battery and mains power supply, hit the power switch to drain any retained charge. then remove the cmos battery. The cmos battery is on the right under the panel at the top of the keyboard, which can be popped out by gently levering it up at the edges. the key board can then be folded clear, watch for the ribbon cable under it that connects to the motherboard.no other way i know of. You might want to check this location first get to the cmos battery via the removable panel on the bottom right front of the case (other side from the battery). first remove the main battery. next remove the panel, under it you will see a modem card, remove the modem card and you should see the cmos battery to the right side its loke a big watch battery. there will be a connector on the wires going to the battery. remove this to disconnect it. now just push the start button with the machine un plugged, just to discharge any residual power. wait a couple of minutes then reconnect the cmos battery then the modem card, then the main battery. plug it in and start it up. the screen will come up with something like "cmos bad checksum, defaults loaded" do not worry this is normal. if it doesn't start normally, switch it off by holding the on button down until it goes off then restart. it should be fine after that, password gone. you can then get into your bios and set it up to your liking. I recommend not putting in a password. Let me know if this works for you.
JimmyC
Sep 28, 2009 | Compaq Armada M700 Notebook
IBM t42 comes on, beeps twice and goes off, connected and battery
Yes it is the fan, get a can of compressed air and clean the air vents and the CPU fan with that, also i would check into the CMOS battery as it could be dead and needs replacing.
As the laptop starts up hit F1 when you see the IBM logo and check the date and time, that will be a clear indicator IF the CMOS battery is dead because it will not be the right date and time, it should however let you into windows if you put the date and time right (it may take a couple of attempts)
Good luck
Jun 19, 2009 | IBM ThinkPad T42 Notebook
Change Compaq V6120us cpu battery
I believe that the cmos battery for your particular laptop is located under the keyboard. You must first remove the plastic bezel between the F keys and the monitor hinges. See if there is a little screw from the back that goes through the hinge covers. If so, remove them. There should also be 2 screws underneath the battery that goes to the center of the bezel. Remove these.
Now you can use a small object (tiny screwdriver or the like) to pry up one corner of the bezel, and it should pop right off. There are 3 or 4 screws just above the F keys of the keyboard that have to come out. Slide the keyboard towards the hinges, and it will come out. Carefully remove the ribbon cable from the motherboard, and remove any cover that is there. Walla, the cmos battery should be right in front of you now, so go ahead and change it. Reassemble in the reverse order of disassembly.
Mar 17, 2009 | Compaq Computers & Internet
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
CMOS error - defaults loaded.
It is possible that your CMOS battery is low or dead.It retains the memory power to the CMOS when you turn off your computer. Change it and see if you problem goes away. It's a round silver disk.They are sometimes called coin batteries because they look like a coin. They come out easy and your local Radio Shack or Batteries Plus will have them.
Jan 01, 2009 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
CMOS problem! help!
Change M/board battery
if it keep going flat check all contacts are clean and not distorted
Oct 03, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Where is the CMOS battery?
Yes that was the cmos battery, I'll see if I can find a better solution for this issue for you.
Feb 13, 2008 | Compaq Armada M700 Notebook
Toshiba Satellite A45-S150 Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
