Posted on Nov 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I just downlaoded a song onto my ipod nano and disconnected it from the computer and the screen shows charged and picture of green battery and is stuck. I cannot do anything it just stays this way. ta lilli I am only 12 and do not have the money to pay for this
Lalit Varadpande
Level 3:
  • Master 488 Answers
  • Posted on Nov 23, 2008
Lalit Varadpande
Master
Level 3:
Answers
488
Questions
Helped
155598
Points
1377
Try and restore it to factory settings.how to do is here
http://support.apple.com/kb/HT1339
hope it helps!
While charging ipod on pc songs are no longer on IPOD
When your iPod is connected and brings up itunes, make sure that you have selected the songs you want from the library where they should be saved and dragged them into your playlist folder (located on the left side of the itunes screen). Then disconnect properly using the eject button, also on the left side of the itunes screen.
5helpful
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
2answers
Ipod nano not show (not play) songs
iTunes includes several options to automatically or manually sync videos to your iPod classic, iPod nano (3rd generation), or iPod (5th generation). Read this article to learn more about these two methods.
Products Affected iTunes, iPod nano (3rd generation), iPod classic, iPod (5th generation)
Syncing videos automatically Connect your iPod to your computer and open iTunes. Select your iPod in the DEVICES section of the iTunes Source list.
In the main iTunes browser window, select the Music tab. Select the checkbox labeled "Sync music" and verify that the "Include music videos" checkbox is also selected. You have the option to sync all songs and playlists or selected playlists.
Movies can be automatically synced to iPod. Select the Movies tab and select the option to sync all movies, selected movies, or a certain number recent unwatched movies.
TV Shows can be automatically synced to iPod. Select the TV Shows tab and select the option to sync all TV shows or selected ones. You can also determine which episodes are synced based on if they are recent or unwatched.
Video Podcasts can be automatically synced to iPod. Select the Podcasts tab select the option to sync all podcasts or selected ones. You can also determine which episodes are synced based on if they are recent, new or unplayed.
Click Apply and iTunes will begin syncing the content you've selected to your iPod. Tip: You can use the capacity bar at the bottom of the iPod settings window to determine how much free space is available. The size of a playlist can be determined by selecting it and looking at the bottom of the iTunes window.
The iTunes LCD will display the sync progress and notify you when the iPod sync is complete.
To disconnect your iPod, select it in the Source list and click the eject icon.
Syncing videos manually If your prefer not to automatically sync video content to your iPod, you can setup manual syncing.
In the main iTunes browser window, select the Summary tab. Select the "Manually manage music and videos" option. This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting.
Click Apply. To manually add music videos, movies or TV shows to your iPod, choose one of these categories under LIBRARY in the Source list. Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon in the Source list. To add a playlist, select it in the Source list and drag it onto your iPod in the same ways as a video or song.
When you are ready disconnect your iPod, select it in the Source list and click the eject icon.
2answers
I pod nano 3rd generation frozen
press and hold the center and menu button together to restart it.
hope this helps
3helpful
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
2answers
Ipod nano 2gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
White ipod nano will not stop showing "do not disconnect" icon....
If you need more asistance, let me know. Good luck.
25helpful
9answers
Ipod Problem (Ipod Nano) moel NO A1199
i fix this problem just the ipod need to reboot
hold ok key and then hold menu key it will be restarted and the it will be connected to your PC
Thanks
4answers
Ipod nano
you need to download itunes from the apple website
Switching on problem with I pod
Restart your ipod (hold the middle button, menu button, and play button for about 10 seconds). That will restart your ipod, and should make it work.
If that doesn't work, follow the instructions on iTunes to restore your ipod to the original factory settings.
 Grubhead
Grubhead
SmartAviator
SmartAviator
