Question about Emerson Fans 300 Heating & Cooling Thermostat
Vulcan freeloader 300 gas hot water unit
Has started to drip water from the base of the unit - it is discharging from a small tube and is approx 11 years old.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: has started to drip water from the base of the
If this unit is that old than it is time to replace it. It has lasted longer than many of them do...
Posted on Nov 12, 2009
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
Should our vulcan freeloader drip water from the small pipe, it often blasts steam out....is this normal ?
If you are sure the coolant (antifreeze) that is not diluted with more water than necessary, but if it is diluted should shut off the system and pour new liquid concentrate (antifreeze) and water in a ratio of 1: 1
Nov 03, 2014 | Motorcycles
Low hot water pressure
I am not familiar with the model of heater you have but I thought I would mention; if you don't have a water softener and the thermostat is set to 140 degrees or above in a hard water area limescale can be a possible cause of your problems and it would be wise to take a look inside before you begin throwing money at it.
Feb 13, 2018 | Water Heaters
We are getting a brown colour in our hot water from our Vulcan freeloader (assume this is where its from anyway). Is this a fixable problem or will we need to look at a new unit? The current unit is about...
unfortunately there is no fix other than replacing the tank, it has a lot of rust buildup inside over 18 years, which is a very long time for a hot water tank today.
Aug 30, 2011 | Water Heaters
Hi I am renting a house with a Vulcan freeloader 260 outside boiler. We keep finding that we do not have any hot water, we turned the thermostat dial up and this seamed to fix the problem for a few...
The unit may be undersized for the amount of water you are drawing off. The freeloader is a storage system. As you draw water off, it fills with cold water. On a 260 its not unusual to use at least half that on a long shower, or if someone else ahs the hot tap going. It takes around 30 minutes to reheat the misplaced water up again...
Jul 16, 2011 | Heating & Cooling
I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Sep 20, 2010 | Heating & Cooling
Nov 06, 2009 | Emerson Fans 300 Heating & Cooling...
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Emerson Fans 300 Heating & Cooling Thermostat Logo
1,144 people viewed this question
Top Emerson Fans Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
Are you an Emerson Fans Heating and Cooling Expert? Answer questions, earn points and help others
