CANON IP 4300 CAN NOT CLEAN BLOCKED YELLOW CARTRIDGE
    Sergeant:
  • 291 Answers
Remove the head carriage carefully and clean the head unit from where the yellow ink comes out with a isoprophyll .and try it should help.
Posted on Nov 23, 2008
I have a ip43oo and I get service error B200 What is it?
Your Pixma ip 4300 error B200 definition: Over-heated print head. It sounds like an: "ut-oh', but not a big deal. The reason the print head overheats? Ink needs to be replaced... Replace the ink cartridge that is low (you should have received that message at least once).
I would shut it down to prevent damage, until you can get the ink cartridge replaced.
Mar 17, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My samsung scx 4300 gives toner exhausted replace toner message i need a fix for this
Remove the cartridge and clean the right side connectors and there is a chip in front of the cartridge please clean that one and clean the connectors by using the soften yellow cloth. Now u insert the cartridge, then now the machine will accept the toner cartridge
Techbelkin
Dec 28, 2010 | Samsung SCX-4300 Monochrome Laser...
Green light is flashing on printer - cartridge won't slide back and forth so 4300 printer will not print
If cartridge is in the middle and won't reset to the right, it is likely a bad printhead (BC-21e).
Jan 18, 2010 | Canon BJC 4300 InkJet Printer
How do i change or clean the inktank on a canon ip 4300
Canon support has the following tutorial: (copy and paste the following link into your browser)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=13528
Enter question: "How do I replace or insert an ink tank" > Click "Search" button > View tutorial.
Dec 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Refilling a cartridge
You need to use a very thin needle (25 gauge medical needle works well) on a syringe. There is a tiny hole in the canon 40 cartridge under the label which you need to fill. To refill the color cartridge (canon 41) as you look at the cartridge, the hole at the top is magenta, the hole to the left is blue and the hole to the right is yellow, use a separate syringe and needle for each color. Every now and then you will need to use some cartridge cleaner to soften/clean the sponge in the cartridge. I use 0.5cc of cleaner then let sit overnight before adding ink. You need to be sure the label is replaced well or use good tape to keep the ink from escaping.
Sep 06, 2008 | Canon PIXMA iP1600 Printer
Canon MP510 not printing correct colors; will not print yellow and will only print purple, pink, and blue.
Refill the yellow section of your cartridge. The yellow exit part of the cartridge head could be blocked as well. Read on Google how to unblock clogged nozzles.
Apr 04, 2008 | Office Equipment & Supplies
101 people viewed this question
k24674
jasbo
jasbo
