Question about Toyotomi TAD-30F Portable Air Conditioner
I need the remote control model number
I bought a Toyotomi TAD-30F Portable AC unit and it didn't have a remote. I know it accepts a remote, does anyone have the remote model number so I may attempt to search for one?
5 Suggested Answers
  • 18 Answers
SOURCE: I need to replace the fan on my TAD-30F. Where
http://www.toyotomiusa.com/products/AccessoriesTAD.mv
hope this helps
Posted on Jul 22, 2009
emissionwiz
  • 64286 Answers
SOURCE: I am being told by
we have no diagrams for this unit, contact the manufacturer for a repair manual.
Posted on Aug 27, 2010
ginko
  • 19396 Answers
SOURCE: I have a Toyotomi TAD-32G that doesn't respond to
To program the unit do the following:
Press Power button on AC.
Press mode button to select between Fan, cool and dry,
Press Timer and use arrows to adjust.
Select Fan speed and the AC will start.
Operations are same on remote and on AC panel. If that does not work, then there is a problem, there is no other way to use the remote. Ensure that there is no timer already programmed, and try disconnecting power to reset main AC unit.
If the timer board is not responding, even if you do the above, then either electronic control or remote sensor on the AC may be faulty (electronic board more likely), did you try reporting the problem to Toyotomy? They should be able to send a technician (if under warranty) or to provide the part (IR board ot control board). The contact number is listed on the owners manual.
Posted on Aug 29, 2010
micromatikal
  • 2777 Answers
SOURCE: I have the toyotomi TAD-T38J
That means you have some fairly major hardware failure inside the machine. The control board is my suspicion for sure, it definitely sounds like that is having electrical failure.. Have you called back the Toyotomi service person / people after you confirmed that their suggestion made no difference? This unit is definitely going to need in person service.
Thanks
Tim
Posted on Oct 08, 2010
  • 51 Answers
SOURCE: My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Posted on Jul 11, 2012
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Portable A/C unit will not stay cooling
Install pressure taps, read the pressure & you will find it is probably low on refrigerant. Find & fix leak...charge as needed.
Nov 27, 2013 | Toyotomi TAD-30F Portable Air Conditioner
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
How to fix E1 error code?
If it's a Delonghi Portable AC unit, E1 indicates that the water collection tank needs to be emptied.
If I knew which brand and the model number of what you had, I could be more specific.
Thanks for choosing FixYa.
Sep 11, 2011 | Heating & Cooling
I just don't know how to run the ac . When I bought it they never gave me a Manuel . I looking on line to see if I can find a online Manuel ?? Its a Simplicity Danby 700 btu portable ac
Bonnie, sinc you didn't mention a model number, it's a little hard to help you. I did find an Owner's Manual for a Danby 7000 btu Portable AC, that may be the one you have. I have included a link to it that you can download and print for future reference. If this is not your model, contact Danby Customer Support 800-263-2629 and they can provide one to you.
http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf
I hope this helped you. Please let me know. Thanks.
Jun 28, 2011 | Heating & Cooling
hope this helps
Jul 22, 2009 | Toyotomi TAD-30F Portable Air Conditioner
Light on plug doesn't come on
try opening it up to see if there's a fuse inside.
Aug 18, 2007 | Toyotomi TAD-30F Portable Air Conditioner
Toyotomi TAD-30F Portable Air Conditioner Logo
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
