Question about Plumbing
Basement sump pump is continously running without water present.
No running water, toilets, etc
house is in dry phoenix AZ,
no rain
  • Anonymous Mar 31, 2014
    crock doesn't even get half full and ;pump starts pumping
  • 15,935 Answers
Check the float. It probably needs an adjustment or cleaning.
Posted on Dec 22, 2008
Kohler 3810 toilet wom't flush
Check and see if the handle or the chain inside the tank is broken. If it is, find out the make and model and get replacement. There are many different types of handles out there. Some universal handles won't work, so bring the handle with you when you buy a new one..
Mar 24, 2017 | Kohler Plumbing
Why is their about 15 gallons of water built up under my house within a couple of days, but no visible leaks?
Drain pipes might go under the ground. You have slab leak. Plumber will figure it out, or check blue prints of Your house if You have those(will show You "What Where")
Jan 29, 2015 | Plumbing
Sump pump
I am presuming you're asking about a basement sump pump, the kind that keeps your basement dry. Well, those things are not meant to run all the time. They are usually triggered by a float valve. That is a device that moves according to the water level in the sump (in other words, the hole). When the water gets high enough, the float activates a switch, the pump kicks in, the water is flushed away, the float falls and that turns the pump off until the cycle starts all over again. The frequency of the cycle depends on how fast the sump fills itself. I have one that kicks in five times a minute. Another might have a much longer off time. But don't be worrying about yours not being on all the time... that is how they are supposed to behave. Of course, if you have water flowing out the top of the sump, that is a sign things are not right with the pump. Then you really need help.
Jun 25, 2014 | Health & Beauty
Our water pressure in our house is gone. we have a well. do you think the well is out of water? do we just need to wait till it rains?
If you did manage to run enough water to dry the well, it should only be temporary, until enough groundwater flows back to your well. This should only take maybe an hour and shouldn't depend on frequent rain. If your well did respond to rain, your well would be quickly contaminated. However, there could be other problems. If you have the type of well where the pump is located down in the ground, and your water pressure doesn't come back soon, then you have a problem in that the pump is not working. If you have a "shallow well" type of pump, where the pump is located above ground (in your basement, or under the house) then the pump may have lost it's prime. A shallow-well pump needs the pump to be full of water before it can pump the water from the well.
Jul 30, 2010 | Plumbing
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
Sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Mar 12, 2009 | Genius Wayne Submersible Sump Pump With ...
How to Install plumbing in the basement?
A sewer ejector pump is the answer. The waster line is run into the sump basin, pumped through a checkvalve into  the sewer line that grades with gravity.  A vent pipe needs to be run also, (you can't pump out without replacing the air, it's like trying to suck air out of a bottle) If you add a high water alarm, which is a good idea. It is run off of a separate electrical breaker (insurance) to let you know if the pump isn't working before it's flood time.  The check valve makes sure, that what you pump out, stays out. Otherwise the pump will keep cycling.
Aug 27, 2008 | West Brass WestBrass Faucet Master Large...
Plumbing Logo
860 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
