Question about Refrigerators
GE tfx24zr fridge
Moving to a new house - the fridge came with the house - no manual...
How do I change the water filter for this fridge? Where is it located?
Thanks in advance!
  • tidwel_l Apr 11, 2009
    Mine is a g.e. model TFX24FHB but I have the same problem...I bought it used at auction....Water is funky...I can't find the filter...
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
  • 363 Answers
SOURCE: location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Posted on Jul 22, 2009
  • 1891 Answers
SOURCE: Need new water filter housing.
could not find your moder # / but the gss25 uses a filter asm and tube pt # wr17x11618 cost( 51.50 ) also newer style filter pt# cwf cost 34.99 ) re ck your mod # on the machine ( do not use the instructions that came with it . any appl parts dist should have these parts .. they are very common .. mm ..
Posted on Dec 02, 2009
  • 5 Answers
SOURCE: Where is the water filter
Depending on the model, it is inside the fridge.
Some other models the filter is on the bottom grille, twist kind.
Look for your manual or look for those clues
Posted on Feb 19, 2010
spectaculusc
  • 321 Answers
SOURCE: Where is the water filter for the ice maker
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Posted on Jan 26, 2011
Ge smartwater filtration system has slow moving water
You have to prime air out of new filters. Also if you have a reverse osmosis water system, your water pressure may not be sufficient.
You may have to bypass the filter. Most fridges come with a plug that will fit where the filter goes. good luck
Dec 27, 2013 | GE GXRLQR GE SmartWater Inline Filter...
I have a GE MWF water filter that is dripping water into the refrigerator. Fridge is about 8 yrs old and have changed many of the MWF water filters. 1st time with this problem.
Many times fines from these filters become dislodged and plug up the filter housing. If you have the bypass plug for the filter, install it and run a couple gallons of water through fridge to flush the system completely. The install the filter again. Make sure none of the water lines feeding fridge are pinched or kinked and valve is on all the way.
RJ
Nov 30, 2010 | General Electric GE SmartWater Household...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Dec 02, 2009 | GE GSS25SGRSS Side by Side Refrigerator
We purchased foreclosure house that has a GE fridge tpx21prx-possibly 13 years old-no info but does it need filter for ice and water use? There is no filter inside fridge-does copper line need replacing...
This model does not have a filter for the ice and water, you can add an inline filter in back of fridge water line, they sell them at any hardware store, you dont need to change copper line unless it is corroded.
Sep 19, 2009 | Refrigerators
About 15 yr. ol GE Profile
YOU MIGHT NOT HAVE ONE ge started puting factory filters on in 1999 . you might have an inline one in the water line behind the fridge . but only if the homeowner or installer put one in , ge has nothing to do with it .... replacements at any hardware store
Feb 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water sprays out of filter spout when I remove water filter
noremally you would take and shut off the water too the filter and relleive the pressure before you attempt to remove the filter.
Dec 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung rs21dcsv refridgerator
THE PROBLEM CANT BE ON THE FRIDGES PIPES.THE PROBLEM MUST BE AT THE FILTER OR ON THE WATERSUPPLY.
Feb 13, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
251 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
