Question about Toshiba Satellite A40 Notebook
Not detect the new Hdd on Notebook Toshiba Satellite SA40-271
The old Hdd is crashed. I have buy a new Hdd ( identically with the original ). I I have replaced. The problen is that in BIOS apperas the following option which can not be modified : Hard Disk Mode = Not Used. Also if I put the old Hdd again it will be detected.
When I replaced the Hdd I have get out the batery, also the power cord and waiting for 45-60 minutes, maybe the Bios is will be resetted, but nothing happend. Also I have look if I have near the battery conector some jupers for reset the Bios but there is nothing like this.
Please help me! What I have to do to detect the new Hdd ?
  • 8 more comments
  • cuparencuv20 Nov 23, 2008
    No !
    The model of the Hdd is : MK4025GAS
    HDD 2190 C ZE01 S
    Notebook Type : Toshiba Satellite SA40-271
    Model No: PSA40E-09XD2-SP
    The Hdd doesent have jumpers
    The capaity of the Hdd : 40 Gb.
    Other information for help ?
    Maybe exist other CMOS Baterry which is resonsable for the data stored in BIOS ? In that case where is localized in Notebok and how I can reset the old settings ?
    Other problen which can be related with this :
    When I start the notebook and press ESC to enter to BIOS - Before ask me to press F1 to enter in setup It promp the following message : IDE #0 Error
  • bloodyfirst8 Mar 29, 2009
    Hey, I've got the same problem and I need to buy a new one, which is the model of the hard disk? thank you
  • Vincent Wright
    Vincent Wright May 11, 2010
    Hello cuparencuv20,
    Does the hard drive have jumpers?
    - Vincent
Forgotten Power On Passwords for Toshiba Satellite A505S6004
If you mean the hdd password, buy a new hdd and start again. There is no way of retrieving it as it is very secure!
Mar 13, 2014 | Toshiba Satellite A505S6004 (PSAT6U009001)...
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Hi everyone. I bought this bad laptop Toshiba Satellite L455D-S5976 from a dealer to find out that it is a refubrished one. It was working fine till one day I turned it on and found that it could not...
It sounds like the motherboard inside it is old, or otherwise cheap. Older used parts are usually already exposed to some heat deformation, and their life time is significantly reduced because of that. Unfortunately, you might be better off / save more money buying a new laptop that runs at lower temperatures.
Mar 04, 2011 | Toshiba Satellite L455D-S5976 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Where can I buy a new battry fo my labtop Toshiba A35-S1592
          You can buy new batteries at the below link
          http://www.laptoppartsshop.com/models/original-Battery/Toshiba-Satellite-A35-S1592
          and also
          http://www.amazon.com/Toshiba-Satellite-A35-S1592-Notebook-Replacement/dp/B0016WFPVA
          Jul 02, 2010 | Toshiba Satellite A35-S1592 Notebook
          I have a Toshiba Satellite P205-S8811 notebook computer. My hard drive is running out of storage. I need more storage for programs and accessories. Can I expand the hard drive, or get an external hard...
          If you do not want to buy a parger HDD for the laptop and clone the existing HDD to the new larger one, then I would go with a larger External HDD and move certain files to it like music and pictures that seem to take up most of the room.
          Jan 18, 2010 | Toshiba Satellite P205-S8811 Notebook
          Toshiba Tecra M1 HDD failure
          no you just put new hdd and run recovery
          Dec 15, 2009 | Toshiba Tecra M1 PC Laptops
          Hello, My Harddisk is 6months old seagate.It was working fine b4 4-5hrs and now i turned on my computer it says No Bootable Device Detected -- Insert boot disk Press any key.My HDD is also not...
          Seems like the harddisk is broken, and it's not really fixable... The good news, however, is that after 6 months the warranty should still be acxtive, so you can send it back to Seagate and get a new one. I hope this answers your question, Yannick.
          Jun 09, 2009 | Toshiba A75-S125 Satellite Notebook
          Cd/dvdrw drive disappears
          try booting in safe mode and see it comes up then
          Mar 08, 2009 | Toshiba Satellite A45-S250 Notebook
          SAT A45 -S121 HDD UPGRADE
          It is possible by opening up the case and removing the old hard drive and replacing it with a new one. You will have to reinstall Windows.
          Aug 23, 2007 | Toshiba Satellite A45-S250 Notebook
          Toshiba Satellite A40 Notebook Logo
          937 people viewed this question
          Top Toshiba Computers & Internet Experts
          pankaj rautela
          pankaj rautela
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
