I couldn't click on my ext lacie 250gig hard drive on my desk. Soooo I unplugged the drive before unmounting and now it won't show on my mac. It gave me a device not unmounted error as well. The light on the drive s on I hear it spinning bt it won't show on my mac. I have an Identical drive and it show just fine. Can you assist me? NATHANIEL BURGESS STYLZKEYZ@GMAIL.COM
bob_computer
  • 3153 Answers
SOURCE: My LaCie 500GB Quadra spins and clicks. Have tried
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Posted on Sep 11, 2009
Testimonial: "Thanks for the quick reply. "
  • 832 Answers
SOURCE: imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Posted on Oct 17, 2009
leitusdotcom
  • 172 Answers
SOURCE: lacie 1 tb hard drive clicks and no recognition
Hi wes_unruh. Unfortunately that "click" , known as the click of death, can mean many things. It could be a head, System Area, scratched platters, etc. First, remove the hard drive from its casing. Then connect the hard drive internally to a computer. You might still get the click. Try a diferent angle and try many many times. Check the logic board for any signs of damage. Please DO NOT start swapping parts because there´s aligment, firmware issues and you can make things worse if you need to do Data Recovery. If you had important informacion, you need to take it to a data recovery company such as Ontrack or ADS, because they have the right equipment such as Deepstar, PCI3000 in order to fully retrieve your files. IT IS an expensive process. I hope this helps. Please do not forget to rate and provide positive feedback for our free support today. Thank you :D
Posted on May 02, 2010
Testimonial: "thanks for the help i seen similar answers but hoped that mine was possibly different or there was a way to fix it ill use the advice"
  • 700 Answers
SOURCE: Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
if you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
Posted on Jul 20, 2010
  • 80 Answers
SOURCE: I cant see my external
for the product that you selected for your question, it is impossible for the LaCie Network Assistant to see it because it is a Local drive (USB).
The LaCie Network Assistant only detects the Network LaCie drives.
Regards,
Posted on Feb 03, 2011
I removed the back up drive from my iMac with out reading directions; just unplugged it! Now I replaced the line into the USB and it is not working and not shoiwng up on the computer. What do I...
Before you unplug an external hard drive, you need to unmount it first. If you don't, you can cause all kinds of problems.The term "unmount" basically means to prepare a drive to be unplugged from the Mac. In addition to external hard drives, "thumb drives" a/k/a "jump drives" as well as some cameras need to be unmounted before they are unplugged.When you unmount a drive, Mac OS X checks to see if you have any open files that are stored on that drive. If you do, the drive cannot be unmounted. This is a safety feature because if drive is removed with open files on it, the application that is using those files can become confused and you can lose or corrupt your data.
If you unplug a hard drive that has not been unmounted, Mac OS X will pop up a box with a red Stop icon and a message that you shouldn't have done that. Nice info, but a little late at that point.
I'm not saying that you will lose data every time you unplug a mounted drive, but the danger is there. I recently worked with someone who had his iPhoto Library on an external drive and he never unmounted the drive before unplugging it. It wasn't a problem for a long time but one time he opened iPhoto and all of the photos were missing.
Unmounting a drive is easy. There is an Eject icon to the right of the drive name in the DEVICES section of a Finder window. Just click that icon.
If you have multiple partitions to unmount, you can hold down the Option key when you click the Eject icon to unmount them all at once.
I thought about it and did some looking and I couldn't find anywhere in Mac OS X that states the need to unmount before unplugging, other than the big Stop icon you get after the fact. I don't think it is something you are likely to think of on your own, either. But now you know.
Oct 07, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
Is Model Lacie 301442U compatible with Mac Pro 10.4.11
According to this website http://www.product-reviews.net/review/20090204/lacie-301442u-1tb-external-hard-drive/ it is compatible with a mac. Hope this helps.
Jun 02, 2010 | Computers & Internet
Will erasing my LaCie ext HD impact any files on my Mac Book?
It will only effect thoes stores on the external harddrive. You will have to check the contents of the LaCie drive and see if it has any files you typically access from your Mac Book. Other then that no it will not effect files stored on your Mac Books drive.
Jan 06, 2010 | LaCie (300728U) 250 GB Hard Drive
My external hard disc worked well until today. Now the external light continues to flicker quickly and the hard disc does not show up on my desk top. I have a mac running Mac OS X 10.5.7. The serial...
There is some thing wrong with file system on your hard disk drive.
Just unplugg it and wait for 1 min, Plugin again.
1) Go to Application -> Utility -> Disk Utility
2) You can see all the drives connected to the machine.
3) Select the drive from left side which acts as external and click on Repair disk button.
Sep 18, 2009 | LaCie Computers & Internet
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
How to correct connection problem for two LaCie Desktop Hard Driv
Here is the support website for the LACIE products.  As far as I knowthis site simply answers questions. Sounds like the hard drives are bad to me.
http://www.lacie.com/support/
Jan 07, 2009 | LaCie Computers & Internet
Not showing up
recheck to insure partitions rexcognized and reinstall unit driver.
Jun 22, 2008 | LaCie Design by F. A. Porsche 80 GB Hard...
 Grubhead
Grubhead
