Question about Sanyo DS32224 TV
Sanyo tv volume
My sanyo tv volume won't go down and the remote or the tv buttons won't do anything and it turned up by its self
Cybertech
  • 149 Answers
SOURCE: no input button
go to localtv shop try getting a used remote for your tv remote original no longer available and is what you need
Posted on Apr 01, 2008
freetek
  • 5568 Answers
SOURCE: Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Posted on Apr 26, 2008
jerryg50
  • 1689 Answers
SOURCE: sanyo 31' tv
The main power supply, or the horizontal output stage may have failed. Sometimes when the horizontal output stage has failed parts, the power supply is also damaged.
An experienced tech should be able to troubleshoot your set for you and replace the defective parts.
Jerry G.
Posted on Apr 27, 2008
SOURCE: OLDER MODEL RCA HOME THEATER PICTURE AND PICTURE
Hi Unykue,
I am an electronics technician who just happened have been given the same set as you because it was giving the previous owner the same problem. Since I am confident in my trade, I took the set and diagnosed noise in the remote receivers input to the cpu.
What this means is that a capacitor( or something) wasn't working properly and was either not filtering the noise out or it was introducing noise into the data stream that controls the TV through your remote control.
My fix was to essentially cut out the entire remote control input to the TV. Since I have a directtv box to give me remote control, I don't care if the TV's remote works anyway.
The way I did this was to open up the unit and find the front I/O board were the buttons meet the switches for power,chaennel, volume, etc. On that board there is a plug with white wires and one black wire. The two wires to cut are the one next to the black wire and the one all the way at the other end of the black wire. These two wires are easy to splice back if you do not like the results of this procedure so that there is really no risk of damaging your set. If you wish to verify the proper wires to cut, they are the two wires that come from the IR receiver's side of the board YET DO NOT GO TO THE OTHER SIDE WITH THE BUTTONS! There is one wire that does indeed go to both sides.
This may not be a perfect solution but it is free. I hope that this will help someone out there.
Len
Posted on Dec 09, 2008
SOURCE: sanyo tv ds25390 buzzing sound
I had the same problem with the same model.
The solution was to replace a capacitor, C622, which is located near
a small blue rectangular plastic component.
This component is a relay that is controlled by C622. I paid $2.39 for
the part, $8.99 for S&H for a total of $11.38. This fixed my problem!
Posted on Mar 11, 2009
RCA LCD TV locked up.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Aug 12, 2012 | RCA RCR312W Remote Control
My sanyo remote model DS27510 won't turn my tv on or off
do you mean you can use only the remote in channel and volume settings but can not use to turn off the tv. ok the problem is just only the power button for the remote. what you need is to clean the rubber contact inside using with an eraser. to do just unclip the lock of the remote controller to remove the housing and to access the internal part.
Jul 21, 2012 | Televison & Video
Dolby rca tv v chip code i need it
Hello
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
Aug 19, 2011 | Televison & Video
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
Jun 09, 2011 | Televison & Video
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
Jun 02, 2011 | GE GTD120 System
How to take of the FPA on a RCA 27V412T
Hello
To unlock the FPA lock of RCA tv, do the following. One amoung the process will surely unlock your RCA. You must have its original remote control handset to do this..
May 22, 2011 | Televison & Video
I was trying to look for the input, and accidently locked the screen
You will need to have the remote:
Press the VOL+ on the remote control and the CH+ button on the front of the TV.
The TV will prompt you to enter a new password.
May 03, 2011 | RCA TruFlat 27F520T 27" TV
Front panel locked by accident- no original remote, only universal, code unknown. tv has since been turned off by unplugging, now it won't turn on. remote has also been unprogrammed because batteries were...
Hello
Three digit universal remote code for RCA are:-
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote code for RCA are:-
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Other ways to unlock RCA tvs
Nov 22, 2010 | RCA 27R410T 27" TV
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
Sanyo DS32224 TV Logo
234 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
