Question about Canon PIXMA MX310 All-In-One Printer
Mx310 canon printer cant scan through print server
Have just connected my new mx310 canon installed drivers connected to belkin 2 port usb print server,printing works well but cannot use scan functoin through server.
can anyone help?
SOURCE: how to redirect lpt print to canon lbp-3000 printer
The LBP-3000 is a GDI (AKA Windows-only) printer, accordingly with its Specifications, so, there's no way to drive it simply redirecting the DOS data flow.
You may want to have a look at Printfil to enable DOS printing to USB/GDI printers
If you're the original Fox programmer, you may also find this article useful: How to print from Clipper DOS to any Windows printer (well, it was written for Clipper, but Clipper and Fox are pretty similar)
Hope this help.
Regards,
Davide
Posted on Aug 04, 2008
  • 35 Answers
SOURCE: No printing with Windows XP Media Center Edition, Version 2002, Service Pack 2
Have you tried all USB ports? or installed the drivers?
Posted on Aug 19, 2008
Ajkill
  • 2035 Answers
SOURCE: printing a banner via canon mx310
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
and select printing banner and then apply ok then start printing
Posted on Oct 12, 2008
SOURCE: Canon LBP-800 don't print on a network
I have tried to print with Canon LBP-800 with 2 different print servers and no success. It seems this printer cannot be used with a print server... only with a direct connection to a computer... it supports printer sharing from windows... hope this helps...
Posted on Nov 04, 2008
vegakitten20
  • 685 Answers
SOURCE: Canon Pixma MX310 won't scan or print
try unplugging it for a little bit then plug it back in and try again if this doesn't work then do a fresh install
Posted on Nov 19, 2008
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
Printer is on but appears to be offline to desktop
If you have already checked to see that the USB cable was plugged-in at BOTH ends.
Try disconnecting the printer from the back of the PC and moving it to an un-used USB port. See if the system detects a new device connected, (it will install drivers automatically if it does.)
If it does not, then the cable may be damaged, get a new USB cable.
Tallon41
Sep 18, 2012 | Canon PIXMA MX310 All-In-One Printer
How to connect my printer to a router
This model Canon printer has onlt an USB connection to a computer.
The only way to connect this printer to a router is to install a printer server with an USB connector, connect the printer to the print server and then connect the print server to the router using a LAN cable.
The printer driver needs to be installed on all the computers on your network and then to the printer properties then Port tab and add a TCP/IP port then configure this port with the print server's IP address.
Do a test print and if the test print is OK then printer is installed correctly.
May 29, 2012 | Canon iP2700 Inkjet Photo Printer
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Using D-link dp-300 Printer Canon ImargeClass MF4350d (Multifunction printer) Problem. I can not use scanner fanction. (no problem for printer) Without printer server, I able to use the scanner.
The problem you are having is pretty standard, the IP based printing works for most printers but the scanner require direct(or well faked, direct) connectivity with a USB port which most routers do not provide.
Several companies including Startech and Io Gear make Virtual USB devices which would resolve the issue.
How they work differs as instead of creating an IP printer, the usb device installs on an ip and then a driver you install on your PC(s) connect to the unit over the router and sets up a virtual USB port on your machine so you can re-install the printer as a local printer attached to what it thinks is a local USB port.
Doing this will allow you all functionality the printer offers but will slow down printing and scanning a bit
Hope this Helps,
Chris
Armor-IT
Apr 24, 2009 | D-Link DP 300U (DP-300U) Print Server
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Oct 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing to a Canon MX310 through a print server
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Nov 11, 2007 | Canon PIXMA MX310 All-In-One Printer
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
Canon PIXMA MX310 All-In-One Printer Logo
331 people viewed this question
old marine
old marine
