Question about Whirlpool GEQ9800P Electric Dryer
Dryer heating element(s) are inconsistent
A friend of mine has a Whirlpool GEQ9800PW1 electric dryer. I helped him to disassemble the dryer to remove any excess lint (in the lint screen / blower area, heating element cylinder, dryer frame, etc.) and try to troubleshoot why the drying operation is inconsistent. In the heating element cylinder, resistance was measured on the three elements. The elements (from the door to the rear of the dryer) measured approx. 200 ohms , 20,000 ohms , and 200 ohms respectively. Reassembled the dryer and started the unit with the heat setting on hot / heavy. With the lower guard removed, the elements glowed. Tossed in a load of clothes and the elements glowed for about 20 secs. then nothing. With the dryer still running, the heat dial was turned back to the next lower setting and the elements started glowing again. About 30 secs. later, again nothing.
Is the element with a 20,000 ohms reading shot ?
  • ab51block Nov 23, 2008
    Yes, the resistance readings were taken with the wires on them.
    There was quite a bit of lint in the element cylinder and it looked as if some of the lint may have even burned itself to the cylinder in a couple of places as the sheet metal had a dark color to it.
    Will have him look at the cylinder and look into thermostat replacement.
    Sergeant:
    Champion:
  • 324 Answers
There is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Posted on Nov 23, 2008
  • with the wires on you will not be reading the thermostats properly.the discolored metal is normal.
What is the part number for the heating element in a whirlpool estate dryer 2406026-fm54?
There are different ones, so you need to disassemble enough to get a good look at it, then click on this link to repairclinic.com
http://www.repairclinic.com/Shop-For-Parts/a8b5c42-x776869726c706f6f6c2032343036303236666d3534/Whirlpool-2406026Fm54-Whirlpool-Dryer-Heating-Element-Parts
and order it. . . They also have movies here giving you some direction on replacing your element . . You'll save a good bit of money . .
Jul 20, 2014 | Estate EED4300TQ Electric Dryer
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool GEQ9800PW1 Electric dryer and I opened the door to dry some clothes and the interior light was out so I immediately checked the circuit panel to see if it had blown a fuse, it had not. ...
The fuse to this dryer is inside behind the filter housing beside the thermistor.themobilian_592.jpg
Pop that bottom panel and remove the filter housing to get to this fuse.
Dec 28, 2010 | Whirlpool GEQ9800P Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool dryer not heating-
HI, To get to the element, you have to remove the lower front panel. You will see the element on the right side under the drum.
With the dryer running, you should have 240V the the two terminals on the element.
If there is voltage, replace the element. If there is no voltage, check the thermastats and the fuse. UNPLUG the dryer and check them for continuity. They should be closed.
This dryer is worth fixing. They are good ones.
I can help you with part #'s or answer more questions if yyou need.
I hope this helps
Vic
May 23, 2009 | Whirlpool GEW9250 Electric Dryer
Heat element
if your dryer isn't heating, it's possible that your heating element needs to be replaced.
are either of these pictures of your dryer?
Whirlpool dryer 1
whirlpool dryer 2
May 15, 2009 | Whirlpool WED5521SQ Electric Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Electric whirlpool dryer works but no heat
Sounds like a new heater element is required - change mine for the same reason and got some sucess - now have a different problem.
Jan 10, 2009 | Dryers
My Whirpool GEQ9800PW1 will not heat
just set your ohm meter on continuity where it will beep when you touch the meter leads and then test the parts all should beep
Dec 15, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
326 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
