Need code for reciever to program comcast remote
I have a sherwood RX4030Rn receiver and want to program my comcast cable remote to work the receiver. I think I need a five digit number. It is not listed in the comcast instructions. Any help?
Thanks! I am too lazy to get up to turn up the volume....
  • Guv66 Dec 30, 2008
    I'm looking for a code for the Sherwood 2.1 dvd surround system
  • Anonymous Jan 19, 2009
    same issue... looking for a comcast code for a sherwood RD-6108
5 Suggested Answers
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Posted on Jun 02, 2008
marklights54
  • 12 Answers
SOURCE: sherwood rd7103 rec.
no listing for Sherwood receiver. must do the remote "search" function. here is how:
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope that helps!
Posted on Mar 01, 2009
greenspan
  • 1734 Answers
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
  • 403 Answers
SOURCE: How can I Program this to comcast digital cable.
Most universal remotes work the same. Try this. Just keep in mind when you select your item select cable.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
  • 60 Answers
SOURCE: I have comcast cable and an oleva flat screen tv. I need to
http://tv.manualsonline.com/manuals/mfg/olevia/lt37hvs.html
try that
Posted on Oct 16, 2009
What are the codes for the RCA RCU600D to program a Sherwood RD-6500 reciever
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jun 10, 2016 | RCA RCU600D Universal 6 Component...
Find remote code for sherwood rd6500 reciever
The only place you will find those codes, are in the back of the owner's manual. There is usually a general procedure to find a code that works, if they don't show the make and model number in the manual.
If you don't have the manual, I'm sure it on their website.
Feb 28, 2015 | Sherwood RD-6500 Receiver
I have a sherwood rc-107 and can't find the code for my grey comcast remote.
Hi John,
You may view the manual and code of your remote control, click this link http://www.comcast.com/corporate/customers/customer_support/remotes.html.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 19, 2011 | Sherwood RX-4103 Receiver
I want to program the aux thing on my comcast remote to work on the volume of my reciever i need the codes?
There should be a "cheat sheet" on the inside of the battery compartment on the comcast remote, if not, simply contact a Comcast customer service tech and they should be able to walk you through programming your device. Most of the time there is a universal code (9,9,0,0) or something similar. Your best bet is to contact your cable operator.
Dec 11, 2009 | Pioneer VSX-516-K
Sherwood rd7103 rec.
  1. Turn on your TV.
Hope that helps!
Feb 28, 2009 | Sherwood RX-4103 Receiver
Need remote code for sherwood rx-4109
Comcast came and the receiver / tv was not capable of being run by another remote as far as volume, just off and on
Jul 20, 2008 | Sherwood Audio Players & Recorders
Need codes for comcast remote to ilo tv
When programming your Comcast universal remote for your TV, the programming guide states that you should enter the 4-digit code provided for your equipment, and if you did it correctly, the TV button will blink twice.
What you have to do is put a "1" in front of your 4-digit code, making your code a 5-digit code. For instance, the code for my Panasonic is listed as 0250. I tried and tried. Then I entered 10250 and it worked perfectly the first time. I did it again to make sure I wasn't seeing things, and it worked.
Good luck.
Apr 10, 2008 | Audio Players & Recorders
Need the remote control code/s
I google'd remote codes for this device. code 1007 seems to work as far as volume controls and the off/on switch goes.
Sep 07, 2007 | Sherwood RD-6108 Receiver
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Electro Med Services...
