Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Not working My step dad has a new hd tv, new hd Antena with a signal boost on its. Still cannot get it to pick up chanals. says low signal, and analog on he screen. Will not auto scan. Help. Set didital on menue still says analog on the screen. Antena is pointed at the towers east of his home about 15 miles away???????????
Ok the problem was in the set up had to let it run through all the analog chanels and then through the didgital ones. After that it worked great. Thanks for the infoI read this on you sight so I tried it worked so were good.
Posted on Nov 24, 2008
Snow on scren only Will not change chanals either using remote or tv contol Do I need a turner? if so where can I obtain same? call Tom @ 1-314=822=7373 TV about 30 yrs old think I had a power surage
any tv 30 yrs old is surely analog , these wont work in todays environment as the ole government did away with all those analog goodies , you'll need a converter to convert the new 1080P HD pictures down to the fuzzy analog signal so your tv can see them , unless its a family heirloom with a fantastic looking wooden cabinet id be looking to get a new HD tv to replace it
Feb 29, 2016 | Televison & Video
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
I have lost Sky Channel 82 from Freeview on Samsung HD TV I have tried to reinstall but channel 82 is still missing
U have more than one tv?Yes.Tries check on the other tvs see if u have channel 82 freeview channel,freeview channels are take out or add on all the times by the tvs stantions broadcasting listing.If yes channel 82 is on the other tvs.Than u have low or weak antena signal.U have a analoge antena probally correct?Buy and install a digital antena,u will get a stronger longer ranges tvs incomming broadcasting chaanels tvs stations.Rescan for channels again,u will pick up channel 82 if it still on the air.
Aug 11, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
Is this model HD ready?
Yes,this tv is able to play HD signal,but must have pay cable or satellite signal hook it up to it.This tv is CRT-(tube tv) analog design tv,antena alone will not work without a converter box.
Feb 17, 2011 | Toshiba 50A50 50" Rear Projection...
My 32av502 tv was just disconnected from satellite & now I can't get the tv to work. It won't pick up any local channels & I don't know how to reprogram them in.
Processor could have some garbage in it, unplug it from the wall and leave it unplug for 40 MIN> then it will reset back to normal.
Jan 11, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
JUST BOUGHT A NEW SAMSUNG TV WITH BUILT IN FREEVIEW BUT CAN'T GET ITV4 AND FILM4. CAN ANYONE HELP? BEEN READING SOME OF YOUR PAST HELP MESSAGES RE - RETUNING WITH REGARD TO TRANSMITTERS, BUT THIS LOOKS...
U have a roof or a good antena like a Digital antena?Take that antena wire hook up to the tv hole that said ANT.Now,turn on the tv.Push the button said menu on the tv remote,go to SETUP,go down to CH. push and pick AIR Not CABLE push it again.Now the tv will auto searching for all the DVTV free air stations in ur area.After this ur tv should getting all the free air DTV broadcasting signal in ur area.
Oct 27, 2010 | Samsung LE37R72B 37 in. HD-Ready LCD...
Can you get a signal without cable or a converter box
Yes,if ur tv is a LCD or a Plasma tvs.It have the tuner inside already it will recieve the digital tv free air brocast.Must have a good antena though like a roof antena,or a digital inside antena.To get excellent signal.So it would cut in and out the broscast of the free digital signal.
May 25, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
I only have cable antena what kn i use because my tv only has hd
you can use a out door aerial or sattelite or cable as long as its a hd signal the set will pick it up unless it doesnt have a hd ready tuner some sets were capable not ready
if it is a hd ready it should have the correct equipment interanl for it then
Oct 30, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
124 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
