Question about Kenmore Washing Machines
Washing machine is leaking
I have a Kenmore front loading washing machie, model 417.41142000. Not much water is getting out but it just started recently after several years of problem free use.
  • dknbawalker Nov 23, 2008
    The washer is leaking just a bit of water. Nothing is coming out from the door. Is there an interal gasket I can replace
    President:
  • Kenmore Master
  • 2,651 Answers
You can remove the front panel(3 screws across the very bottom lip) from there you wil gain acess to view the underneath, as the macine is operating to pin point where the leak is coming from
Posted on Nov 23, 2008
Water leaks with larger louds on kenmore front load eco
Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Kenmore Washing Machines
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
When i start wash. machi. pump starts and few sec.later led flash
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
Dec 10, 2008 | Whirlpool AWM6120 Front Load Washer
Water standing in tub after cycle has been completed
hi i only fix uk machies but from what you are saying it sounds like the pump may be blocked ,have a look behind the lower panel at the bottem of the machine to see if there is a filter if so try to empty that,hope that helps.
Nov 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
134 people viewed this question
Sal De
fordexpert
Robert Rankin
